.NET
UCS rotation
4 REPLIES 4
490 Views, 4 Replies
UCS rotation
I am working in a UCS that was created by rotating the WCS around its Z
axis by certain degrees. How can I find out that angle of rotation?
Basically I need to find the angle made by the current UCS' X axis with
the WCS' X Axis. Any help is much appreciated!
Thanks!
Gagan
4 REPLIES 4
{code}
Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
Vector3d v = ed.CurrentUserCoordinateSystem.CoordinateSystem3d.Xaxis;
double answer = Vector3d.XAxis.AngleTo( v );
{code}
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
"Gagan Gajabaharia" wrote in message news:6074591@discussion.autodesk.com...
Thanks!
Gagan
chiefbraincloud
This code uses Editor.CurrentUserCoordinateSystem, and returns the angle in radians.
Friend Shared Function GetUCSRotation() As Double
Try
Dim CurUcs As CoordinateSystem3d = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocum ent.Editor.CurrentUserCoordinateSystem.CoordinateSystem3d()
Dim WorldNormal As New Vector3d(0, 0, 1)
Dim CurXvec As Vector3d = CurUcs.Xaxis
Dim WorldXY As New Plane(CurUcs.Origin, WorldNormal)
Return CurXvec.AngleOnPlane(WorldXY)
Catch ex As System.Exception
EdWrite(ex.Message & " In: " & ex.Source & vbCrLf & ex.StackTrace & vbCrLf)
Return Nothing
End Try
End Function
Tony Tanzillo wrote:
> {code}
> {code}
Thanks, Tony! I got the idea..
Gagan
> in radians.
> Try
> Return Nothing
> End Try
End Function
Thanks, Chief!
Gagan
”Boost
