.NET
UCS by block
4 REPLIES 4
f.roels
624 Views, 4 Replies
UCS by block
Hi all,
VB.NET is pretty new to me (I'm sorry if I ask stupid questions). But now I have a problem with UCS in VB.NET.
I try to write a routine in VB.NET which place the UCS accoording u block (sames as the AutoCAD command: UCS - Object)
I had succeeded in VBA. But don't know how to start in VB.NET.
code:
Dim bref As BlockReference = DirectCast(tr.getObject(BlockRefID, OpenMode.ForRead), BlockReference)
ed.CurrentUserCoorinateSystem = bref.Ecs
This is not the way. The UCS stays the same, while the block was rotated 15°. (I think this reflects the UCS when the block was placed)
-Filip-
4 REPLIES 4
Alfred.NESWADBA
in reply to: f.roels
check this:
   Public Shared Function setUcsToBlockRefMatrix() As Boolean
      Dim tRetVal As Boolean = False
      Dim tAcadDoc As Document = Nothing
      Dim tAcadDocLock As DocumentLock = Nothing
      Dim tTrAct As Transaction = Nothing
      Try
         tAcadDoc = Application.DocumentManager.MdiActiveDocument
         tAcadDocLock = tAcadDoc.LockDocument
         tTrAct = tAcadDoc.TransactionManager.StartTransaction
         Dim tEntPrompt As PromptEntityResult = tAcadDoc.Editor.GetEntity(vbNewLine & "Select BlockRef: ")
         If tEntPrompt.Status = PromptStatus.OK Then
            If tEntPrompt.ObjectId.ObjectClass.DxfName = "INSERT" Then
               Dim tBlRef As BlockReference = CType(tTrAct.GetObject(tEntPrompt.ObjectId, OpenMode.ForRead), BlockReference)
               tAcadDoc.Editor.CurrentUserCoordinateSystem = tBlRef.BlockTransform
               tTrAct.Commit()
            Else
               tAcadDoc.Editor.WriteMessage("Select BlockRef - selected entity was no BlockRef.")
            End If
         Else
            tAcadDoc.Editor.WriteMessage("Select BlockRef - input canceled")
         End If
      Catch ex As Exception
         Call MsgBox("Error occured!" & vbNewLine & ex.Message)
      Finally
         If tTrAct IsNot Nothing Then tTrAct.Dispose() : tTrAct = Nothing
         If tAcadDocLock IsNot Nothing Then tAcadDocLock.Dispose() : tAcadDocLock = Nothing
      End Try
      Return tRetVal
   End Function
 HTH, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
f.roels
in reply to: Alfred.NESWADBA
thanks
it works perfectl. Have you got a piece of code that you can rotate the UCS around its X, Y and Z axis
best
Filip
Alfred.NESWADBA
sorry, lost this thread ;(
One sample is enough?
'first a MOVE/ROTATE/SCALE-transformation to be equal to BlockReference
Dim tMat1 As Matrix3d = tBlRef.BlockTransform
'now a definition for a rotation of 45° where rotation-axis = Z-axis
Dim tMat2 As Matrix3d = Matrix3d.Rotation(Math.PI / 4, New Vector3d(0, 0, 1), Point3d.Origin)
'combine these
Dim tMat3 As Matrix3d = tMat1 * tMat2
'set UCS
tAcadDoc.Editor.CurrentUserCoordinateSystem = tMat3
 HTH, - alfred -
Alfred NESWADBA
f.roels
thanks a lot
Filip
”Boost
