.NET
TypedValue filter by color with bylayer`
6 REPLIES 6
absStructural
1118 Views, 6 Replies
I have a filter set up like this:
TypedValue[] filter =
newTypedValue[]
   newTypedValue((int)DxfCode.Operator, "<OR"), // crossframe or bearing color
   newTypedValue((int)DxfCode.Color, Autodesk.AutoCAD.Interop.Common.ACAD_COLOR.acRed),
   newTypedValue((int)DxfCode.Color, Autodesk.AutoCAD.Interop.Common.ACAD_COLOR.acWhite),
   newTypedValue((int)DxfCode.Operator, "OR>")
I then create a SelectionFilter with this TypedValue array, and use Editor.SelectAll(selectionFilter) to retrieve the desired entities.
The goal is to select all entities that are either red or white.  This works fine - except I also want to include entities that are ByLayer - if the color of the layer is red or white.
Is there any way to do this in a single filter?
6 REPLIES 6
_gile
in reply to: absStructural
You can try this way:
string layers = string.Empty;
using (Transaction tr = db.TransactionManager.StartOpenCloseTransaction())
    LayerTable lt = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForRead);
    foreach (ObjectId id in lt)
        LayerTableRecord ltr = (LayerTableRecord)tr.GetObject(id, OpenMode.ForRead);
        if (ltr.Color == Color.FromColorIndex(ColorMethod.ByAci, 1) ||
            ltr.Color == Color.FromColorIndex(ColorMethod.ByAci, 7))
            layers += ltr.Name + ",";
    new TypedValue(-4, "<OR"),
    new TypedValue(62, 1),
    new TypedValue(62, 7),
    new TypedValue(-4, "<AND"),
    new TypedValue(62, 256),
    new TypedValue(8, layers),
    new TypedValue(-4, "AND>"),
    new TypedValue(-4, "OR>")
Gilles Chanteau
GileCAD
GitHub
absStructural
in reply to: _gile
Not quite as straight forward as I would like - but that works.
Thanks!
BKSpurgeon
_gile
in reply to: BKSpurgeon
BKSpurgeon a écrit :
For future readers, this is a much better way:
http://through-the-interface.typepad.com/through_the_interface/2008/07/conditional-sel.html
Why do you think it's a "much better way" ? It seems to me it's exactly the same way using relational groups...
Gilles Chanteau
GileCAD
GitHub
k005
in reply to: _gile
If we add a third color in this code, how should we change the code?
and it doesn't select the colors that are Bylayer in this filter. Where does this originate from?
I am attaching the sample file.
k005
in reply to: k005
With this selection filter, colors belonging to the 62 code are selected. But Bylayer ones are not selected..! where is
wrong with this code? ?
Is there anyone who can help?
Thank you.
      TypedValue[] acTypValAr =
                 new TypedValue(62, ilkRenk),
                 new TypedValue(62, ikinciRenk),
                 new TypedValue(62, ucuncuRenk),
”Boost
