.NET
Trying to find a specific item in an XREF
2 REPLIES 2
467 Views, 2 Replies
All,
I am wondering if there is a way to select a single entity (with the cursor) from an XREF object embedded within my current active drawing. I can use GetEntity to determine what objects are part of my xref, but I need to identify certain pieces as points of reference.
So if I have a large drawing of circuits (single line) and what not, I want to be able to point at a specific circuit segment and get length and width information for the line representation of that circuit line.
Kyle
2 REPLIES 2
chiefbraincloud
It is unclear from your question wether you are using the Managed API or COM (or VB or C#).  If you're using COM, then I think there is a GetSubEntity in Utility.  I don't have an example that hasn't been upgraded to the Managed API.
If you are using the Managed API It goes like this:  (ApplicationServices and EditorInput Imported)
Dim PrNestOps As New PromptNestedEntityOptions("Select Xref Object:")
PrNestOps.AllowNone = False
PrNestOps.UseNonInteractivePickPoint = False
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
Dim PrNentRes As PromptNestedEntityResult = ed.GetNestedEntity(PrNestOps)
If PrNentRes.Status = PromptStatus.OK Then
'PrNentRes.ObjectId is the ID of the base object picked
'PrNentRes.PickedPoint =the point picked
'PrNentRes.Transform = the block transform to convert points and angles to WCS
'PrNentRes.GetContainers() returns an array of ObjectID's pointing to each container object
in reply to: chiefbraincloud
Yes, I am using the Managed API (C# specifically). I will give this a shot, thank you for your response.
”Boost
