.NET
Trying to erase a text object
3 REPLIES 3
david_sexton
351 Views, 3 Replies
Hello, all.  I've got a sub that grabs all of the text objects in a drawing and then compares the first 20 characters to a defined string.  I want it to be able to erase any objects that are a match prior to moving on to the next object in the selection set.  With the following code, it does everything but erase the object.  Obviously, I'm missing something but I just can't see why it isn't working.  Any suggestions?
Thanks for your time and consideration
Dave
    Public Sub RemoveDisclaimer()
        Dim myDB As Database = HostApplicationServices.WorkingDatabase
        Dim myDWG As Document = DocumentManager.MdiActiveDocument
        Dim myED As Editor = myDWG.Editor
        Dim dsText As DBText
        Dim dsMText As MText
        Using myTrans As Transaction = myDB.TransactionManager.StartTransaction
            'select all text objects in the drawing
            Dim myBlockTable As BlockTable = myDB.BlockTableId.GetObject(OpenMode.ForRead)
            Dim myTypedValue(3) As TypedValue
            myTypedValue.SetValue(New TypedValue(DxfCode.Operator, "<or"), 0)
            myTypedValue.SetValue(New TypedValue(DxfCode.Start, "Text"), 1)
            myTypedValue.SetValue(New TypedValue(DxfCode.Start, "MText"), 2)
            myTypedValue.SetValue(New TypedValue(DxfCode.Operator, "or>"), 3)
            Dim myFilter As New SelectionFilter(myTypedValue)
            Dim myPSR As PromptSelectionResult = myED.SelectAll(myFilter)
            Dim mySelectionSet As SelectionSet = myPSR.Value
            Dim dsStandard As String = "THIS ENGINEERING JUD"
            Dim dsFCD As String = "THIS FIRESTOP CUSTOM"
            Dim strText As String
            Dim strMText As String
            'cycle through each text object, if it's a match then erase the object
            For Each mySelectedObject In mySelectionSet
                Select Case mySelectedObject.ObjectId.ObjectClass.Name
                    Case "AcDbText"
                        dsText = myTrans.GetObject(mySelectedObject.ObjectId, OpenMode.ForWrite, False, True)
                        strText = dsText.TextString
                        If Left(strText, 20) = dsStandard Or Left(strText, 20) = dsFCD Then
                            dsText.Erase(True)
                            dsText.Dispose()
                    Case "AcDbMText"
                        dsMText = myTrans.GetObject(mySelectedObject.ObjectId, OpenMode.ForWrite, False, True)
                        strMText = dsMText.Contents
                        If Left(strMText, 20) = dsFCD Then
                            dsMText.Erase(True)
                            dsMText.Dispose()
                End Select
            Next 'mySelectedObject
        End Using 'myTrans
    End Sub
3 REPLIES 3
transaction-committing is missing 😉
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
So, I'm a moron.  I wrote that code late yesterday and didn't get a chance to test it until this morning.  I stared at it for 2 hours!!  Thanks a lot!!
Dave
>> So, I'm a moron
Oh no, don't say or think something like that.
IMHO all of us have already searched for a bug in our code before recognizing that .Commit it missing 😉
- alfred -
Alfred NESWADBA
”Boost
