.NET
Member
cyconnely
Message 1 of 3 (217 Views)
Accepted Solution
Trouble with interop Import Command
217 Views, 2 Replies
01-26-2014 04:08 PM
I'm writing a program to import a WMF into the AutoCad Drawing. I haven't been able to find any reference for the import command, so I can't figure out why it's not working. According to Visual Studio, the Import command needs these things to work.
Code:
acadDoc.Import(FileName As String, InsertionPoint As Object, ScaleFactor As Double) As Object
Simplified Code:
Code:
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Interop
Dim AcadApp As Autodesk.AutoCAD.Interop.AcadApplication
AcadApp = CType(GetObject(, "AutoCAD.Application.18.2"), Autodesk.AutoCAD.Interop.AcadApplication)
acadDoc = AcadApp.ActiveDocument
acadDoc.Import("C:\Users\C\Documents\Drawing1.wmf", New Point3d(2, 2, 0), 2.0)
When I comment out the last line of code,
Code:
It runs fine.
The error I'm getting is when I run it AutoCAD,
Code:
************** Exception Text **************
System.ArgumentException: Value does not fall within the expected range.
   at System.StubHelpers.ObjectMarshaler.ConvertToNative(Object objSrc, IntPtr pDstVariant)
   at Autodesk.AutoCAD.Interop.IAcadDocument.Import(String FileName, Object InsertionPoint, Double ScaleFactor)
   at TestSelectingFiltering.TestSelecting.MyCommands.FilterBlueCircleOnLayer0()
   at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker(MethodInfo mi, Object commandObject, Boolean bLispFunction)
   at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorkerWithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
   at Autodesk.AutoCAD.Runtime.PerDocumentCommandClass.Invoke(MethodInfo mi, Boolean bLispFunction)
   at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk.Invoke()
Any help would be greatly appreciated,
Thanks!
*Expert Elite*
norman.yuan
Message 2 of 3 (198 Views)
Re: Trouble with interop Import Command
01-26-2014 06:45 PM in reply to: cyconnely
Well, the error message says exactly why the exception happems: ArgumentException, which means one of the parameter you passed to the AcadDocument.Import() method is wrong.
The second argument of the Import method expects a ARRAY of double (3 elements), representing an point. What you passed in is an Point3d staructure. Acad COM object does not know what Point3d is.
So, you need to change your code like:
Dim point(0 To 2) as double
point(0)=2.0 : point(1)=2.0 : point(2)=0.0
acadDoc.Import("C:\Users\C\Documents\Drawing1.wmf", point, 2.0)
Member
cyconnely
Message 3 of 3 (194 Views)
01-26-2014 06:51 PM in reply to: norman.yuan
Awesome!! Thanks, this was driving me crazy.
You are not logged in.
Announcements
Need installation help?
Ask the Community
