.NET
Trouble getting textstring from attribute definition
62 REPLIES 62
Message 1 of 63
1151 Views, 62 Replies
I have been creating block attributes with some good success. Example:
While btrEnum.MoveNext
Dim ent As Entity = btrEnum.Current.GetObject(OpenMode.ForWrite)
If TypeOf ent Is AttributeDefinition Then
Dim attdef As AttributeDefinition = ent
Dim attref As New AttributeReference
attref.SetAttributeFromBlock(attdef, myBRef.BlockTransform)
attref.TextString = myReader.ReadLine
attColl.AppendAttribute(attref)
trans.AddNewlyCreatedDBObject(attref, True)
End While
Now, when I try to read those attribute's textstrings back later for different reasons, I receive only the "default" attribute textstring instead of the one I inserted earlier in the program. Example:
If attdef.Tag.ToUpper = myTag.ToUpper Then
value = attdef.TextString
End While
Why doesn't this return the textstring value recorded earlier?
Is there an easier way to do this?
62 REPLIES 62
Message 61 of 63
Did you ever get your answer (either here or elsewhere)? If so could you you post the solution that you implemented successfully?
When I search for posts I find myself looking to the original poster person to say that he got an answer that helped him or not.
Let us/me know. I'm trying to figure out how to do this too. And I just ordered the controversial book too.....
My impression is that the answer is in this thread, however I'm not seeing that you agree... Will likely come back to this thread for the sample code.
Message 62 of 63
Here is the For Each Next Solution that Jerry Winters actually worked out for me after I mentioned this discussion to him.
It works, but only for the top level blocks. It does not find any nested block attributes. I'm thinking that the enumeration method will find all the nested blocks as well. The same code is in the attached file also.
Some of the discussion on this subject indicates this is not a difficult problem. I'm not finding it so smple.... but then I'm pretty new as well... However since the question was raised, I wanted to close the loop on this sub discussion.
{code}
Public Function AddBlockAndAtts(ByVal InsPt As Geometry.Point3d, _
ByVal BlockName As String) As DatabaseServices.ObjectId
'Add Block Reference with all the attributes from the block definition.
Dim myTransMan As DatabaseServices.TransactionManager
Dim myTrans As DatabaseServices.Transaction
Dim myDwg As Document
Dim myBT As BlockTable
Dim myBTR As BlockTableRecord
myDwg = Application.DocumentManager.MdiActiveDocument
myTransMan = myDwg.TransactionManager
myTrans = myTransMan.StartTransaction
'Open the database for Write
myBT = myDwg.Database.BlockTableId.GetObject(OpenMode.ForRead)
myBTR = myBT(BlockTableRecord.ModelSpace).GetObject(OpenMode.ForWrite)
'Insert the Block
Dim myBlockDef As BlockTableRecord = myBT(BlockName).GetObject(OpenMode.ForRead)
Dim myBlockRef As New BlockReference(InsPt, myBT(BlockName))
myBTR.AppendEntity(myBlockRef)
myTrans.AddNewlyCreatedDBObject(myBlockRef, True)
'Set the Attribute Value
Dim myAttColl As AttributeCollection
Dim myEnt As Entity
' Dim myBTREnum As BlockTableRecordEnumerator
myAttColl = myBlockRef.AttributeCollection
Dim myEntID As ObjectId
' myBTREnum = myBlockDef.GetEnumerator
For Each myEntID In myBlockDef
' While myBTREnum.MoveNext
'myEnt = myBTREnum.Current.GetObject(OpenMode.ForWrite)
myEnt = CType(myEntID.GetObject(OpenMode.ForWrite), Entity)
If TypeOf myEnt Is DatabaseServices.AttributeDefinition Then
Dim myAttDef As DatabaseServices.AttributeDefinition = myEnt
Dim myAttRef As New DatabaseServices.AttributeReference
myAttRef.SetAttributeFromBlock(myAttDef, myBlockRef.BlockTransform)
myAttColl.AppendAttribute(myAttRef)
myTrans.AddNewlyCreatedDBObject(myAttRef, True)
' End While
Next
'Commit the Transaction
myTrans.Commit()
'Dispose of the Transaction Objects
myTrans.Dispose()
myTransMan.Dispose()
Return myBlockRef.ObjectId
End Function
{code}
Message 63 of 63
Not sure what you mean by 'nested blocks/attributes'.
A BlockReference has attributes, which correspond to
attribute definitions in the block's defining entities.
If there are BlockReferences that are nested in the
definition of a block, which also have attributes, those
attributes are part of another BlockReference that is
inserted into/resides in the 'parent' block's definition.
I think you're going to need to explain more clearly
what you are trying to do. If you have blocks nested
within other blocks, you deal with them in the same
way you deal with 'top-level' block references, except
that the owner is not the modelspace or a paperspace
block, it is the block that contains the nested block
references.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6279865@discussion.autodesk.com...
sub discussion.
{code}
definition.
myBTR =
'Insert the Block
Dim myEnt As Entity
myEnt
' End While
Next
myTrans.Commit()
myTrans.Dispose()
End Function
{code}
”Boost
