• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    *Scott McFarlane
    TreeView label edit in a palette
    224 Views, 11 Replies
    08-25-2005 11:01 AM
    My .NET application creates a new PaletteSet using a user control that has a
    TreeView on it. The TreeView allows label editing, but once you are in label
    editing mode, the control does not respond to either ESC or ENTER. I seem to
    recall having to deal with this issue in a similar ObjectARX application,
    but I'm not sure how to fix it in .NET.
    Below is a snippet of code that demonstrates this issue:
    With New Autodesk.AutoCAD.Windows.PaletteSet("Test Palette")
    Dim objTreeView As New System.Windows.Forms.TreeView
    With objTreeView
    .Dock = Windows.Forms.DockStyle.Fill
    .LabelEdit = True
    .Nodes.Add("Edit this node")
    End With
    .Add("Test Palette", objTreeView)
    .Visible = True
    End With
    Any ideas?
    Scott
    Please use plain text.
    *Mike Tuersley
    Re: TreeView label edit in a palette
    08-25-2005 08:35 PM in reply to: *Scott McFarlane
    I assume you have coded the node's KeyUp event to handle Enter and/or
    Escape?
    -- Mike
    ___________________________
    Mike Tuersley
    the trick is to realize that there is no spoon...
    *Mike Tuersley
    08-26-2005 06:30 AM in reply to: *Scott McFarlane
    Oops, let me rephrase that.! What I meant to say was have you tried
    throwing code into the keyup event for the treeview and the palette to see
    if the event registering at all one either of those keys? If not, you may
    need the same fix for focus as the combobox control.
    -- Mike
    Mike Tuersley
    *Scott McFarlane
    08-26-2005 10:23 AM in reply to: *Scott McFarlane
    Hi Mike,
    Thanks for the reply. The PaletteSet and Palette classes don't appear to
    expose any keyboard events themselves. I tried putting some code into the
    TreeView's KeyUp event and found that it responds to ESC and ENTER. But when
    you go into label edit mode (and the TreeView control creates a temporary
    edit box control to edit the label) those keys seem to be ignored - in fact,
    the TreeView_KeyUp event is not fired at all when the label edit box is
    visible.
    - Scott
    "Mike Tuersley" wrote in message
    news:4939864@discussion.autodesk.com...
    -- Mike
    Mike Tuersley
    *Tony Tanzillo
    08-26-2005 12:36 PM in reply to: *Scott McFarlane
    "Mike Tuersley" wrote:
    > If not, you may need the same fix for focus
    Hi Mike. You might be interested in knowing that
    the 'fix' you posted for the ComboBox problem (for
    not dropping down when you click on the control
    while the palette is floating), actually creates more
    problems than it solves.
    One of those problems is that it corrupts the behavior
    of any control that displays an "in-place" edit window
    (e.g, TreeView, ListView, DataGrid, etc.).
    With your fix, if you try editing a label in a treeview
    or listview, and you click inside the label edit window
    with the mouse, the label edit window looses and
    regains focus, with the entire label text selected.
    What should happen is that you should get a vertical
    blinking bar cursor at the point where you clicked in
    the control, but that doesn't happen.
    I haven't looked at the problem with the treeview
    (and it should also affect ListViews as well), so I
    don't know exactly what's causing it.
    http://www.caddzone.com
    AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
    http://www.acadxtabs.com
    *Mike Tuersley
    08-26-2005 09:47 PM in reply to: *Scott McFarlane
    Ouch! Sorry, I didn't mean for that to happen =( Chalk another one up to
    "slap it in and see if it works to get me to the due date and I'll sort it
    out later"
    I'll look at it and weed out the crap and see if I can't revise it with
    just the focus you mentioned, Tony. Thanks!
    -- Mike
    Mike Tuersley
    *Tony Tanzillo
    08-27-2005 10:45 PM in reply to: *Scott McFarlane
    This TreeView control descendent should solve your problem.
    Just use it in lieu of the Syste.Windows.Forms.TreeView.
    Sorry about the C#, but I don't do VB. Hopefully, somoene can
    translate it for you, or you can build it a separate assembly and
    reference it from your VB project.
    /// DialogTreeView.cs Cooyright (c) 2005 Tony Tanzillo All rights reserved
    /// For private use only. Do not distribute or
    /// publish this code without the express written
    /// consent of the author.
    /// This TreeView descendent addresses the issue
    /// described in KB 130691
    /// See http://support.microsoft.com/default.aspx?scid=kb;en-us;130691
    using System;
    using System.Windows.Forms;
    using System.Runtime.InteropServices;
    namespace StupidControlThunks
    public class DialogTreeView : TreeView
    public DialogTreeView()
    private const int TVM_GETEDITCONTROL = 0x110F;
    [DllImport("user32.dll", CharSet=CharSet.Auto)]
    private static extern IntPtr SendMessage(IntPtr hWnd,
    int msg, int wParam, int lParam);
    private class LabelEditWindowHook : NativeWindow
    private const int WM_GETDLGCODE = 135;
    private const int DLGC_WANTALLKEYS = 0x0004;
    public LabelEditWindowHook()
    protected override void WndProc(ref Message m)
    if( m.Msg == WM_GETDLGCODE )
    m.Result = (IntPtr) DLGC_WANTALLKEYS;
    else
    base.WndProc(ref m);
    private LabelEditWindowHook m_Hook = new LabelEditWindowHook();
    protected override void OnBeforeLabelEdit( NodeLabelEditEventArgs e )
    IntPtr handle = SendMessage(this.Handle, TVM_GETEDITCONTROL, 0, 0);
    if( handle != IntPtr.Zero )
    m_Hook.AssignHandle(handle);
    base.OnBeforeLabelEdit( e );
    protected override void OnAfterLabelEdit( NodeLabelEditEventArgs e )
    m_Hook.ReleaseHandle();
    base.OnAfterLabelEdit( e );
    /////// DialogTreeView.cs ///////////////////////////////////////////////////
    "Scott McFarlane" wrote in message news:4939035@discussion.autodesk.com...
    With objTreeView
    .LabelEdit = True
    End With
    .Visible = True
    End With
    Any ideas?
    Scott
    *Tony Tanzillo
    08-28-2005 10:00 PM in reply to: *Scott McFarlane
    Fixed version:
    using System;
    else
    if( ! e.CancelEdit )
    "Tony Tanzillo" wrote in message news:4941045@discussion.autodesk.com...
    using System;
    else
    With objTreeView
    .LabelEdit = True
    End With
    .Visible = True
    End With
    Any ideas?
    Scott
    *Tony Tanzillo
    08-29-2005 10:01 AM in reply to: *Scott McFarlane
    The code below has a major bug. Don't use it.
    See the next post for a fixed version.
    using System;
    else
    With objTreeView
    .LabelEdit = True
    End With
    .Visible = True
    End With
    Any ideas?
    Scott
    *Scott McFarlane
    08-29-2005 12:38 PM in reply to: *Scott McFarlane
    Hi Tony,
    Works like a charm. Thanks!
    Scott
    news:4941243@discussion.autodesk.com...
    Fixed version:
    reserved
    using System;
    else
    0);
    reserved
    using System;
    else
    With objTreeView
    .LabelEdit = True
    End With
    .Visible = True
    End With
    Any ideas?
    Scott
