.NET
Active Contributor
jimmie_fulton
Message 1 of 1 (229 Views)
TransactionManager.StartTransation() causes null object error?
229 Views, 0 Replies
02-22-2006 11:43 AM
I have an event handler connected to the Database.ObjectAppended to watch when a particular object type has been appended to the database. Within the event handler, it seems that the database is in such as state that I can't get a transaction to query the database with; it causes a null object exception when I call StartTransaction() on the database's TransactionManager. Any ideas why?
// ObjectEventHandler event handler
private static void Database_ObjectAppended(object sender, ObjectEventArgs e)
Database database = sender as Database;
PropertySet propertySet = e.DBObject as PropertySet;
if (propertySet != null && database != null)
ObjectId sheetnoteSetDefId = ObjectId.Null;
// *** Error happens on next line ***
using (Transaction trans = database.TransactionManager.StartTransaction())
using (DictionaryPropertySetDefinitions propertySetDefIds = new DictionaryPropertySetDefinitions(database))
foreach (ObjectId propertySetDefId in propertySetDefIds.Records)
PropertySetDefinition propertySetDef = (PropertySetDefinition)trans.GetObject(propertySetDefId, OpenMode.ForRead);
if (propertySetDef.Name.ToLower() == "sheetnote_data")
sheetnoteSetDefId = propertySetDef.ObjectId;
break;
if (propertySet.PropertySetDefinition == sheetnoteSetDefId)
int number = (int)propertySet.GetAt(propertySet.PropertyNameToId("Number"));
string text = (string)propertySet.GetAt(propertySet.PropertyNameToId("Text"));
SheetnoteInfo sheetnoteInfo = new SheetnoteInfo(number, text);
sheetNoteControl.AddSheetnote(sheetnoteInfo);
You are not logged in.
Announcements
Need installation help?
Ask the Community
