.NET
Transaction not needed?
3 REPLIES 3
SRSDS
515 Views, 3 Replies
Just curious about this. Why would the following code not require a transaction?
Essentially filtering and erasing objects.
            Dim psr As PromptSelectionResult = ed.SelectAll(filter)
            If psr.Status = PromptStatus.OK Then
                Dim idarray As ObjectId() = psr.Value.GetObjectIds()
                For Each ObjID In idarray
                    Dim Ent As Entity = ObjID.GetObject(OpenMode.ForWrite)
                    If TypeOf Ent Is Polyline Then
                        Ent.Erase()
                Next
3 REPLIES 3
DiningPhilosopher
in reply to: SRSDS
                        Ent.Erase()
                Next
The code does require a transaction. If it doesn't fail, it is because there is an active transaction in the document you're running it in.
The ObjectId.GetObject() method simply calls the GetObject() method of the active Transaction returned by the TransactionManager's TopTransaction property, and if there is no active transaction, it will fail.
Hallex
in reply to: SRSDS
Take a look at this page for more
http://spiderinnet1.typepad.com/blog/2012/04/open-direct-or-use-transaction-to-getobject-in-autocad-...
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
SRSDS
in reply to: Hallex
Thankyou both. I did have an open transaction in a parent routine. I didn't realise that it was being used.
”Boost
