.NET
New Member
rafal.watroba
Message 1 of 2 (146 Views)
Transaction & db.ObjectModified event - problems
146 Views, 1 Replies
02-24-2006 05:35 AM
I want to use Database.ObjectModified event to update attributes in block reference.
1. The following code causes AutoCAD critical error:
Public Shared Sub OnObjectModified(sender,e)
Dim trans As Transaction = CType(sender, DatabaseServices.Database).TransactionManager.StartTransaction
Try
' if object is BlockReference and it's MyBlock -> update attributes
trans.Abort
Finally
trans.Dispose()
End Try
End Sub
I get this error even the handler only start and dispose transaction object.
2. I've used trans.Commit finally and it works. But then I get two errors when I save drawing:
"An unhandled exception of type 'System.NullReferenceException' occurred in acdbmgd.dll"
"An unhandled exception of type 'System.InvalidOperationException' occurred in acdbmgd.dll"
[AutoCAD 2006, VB.NET 2003]
Thanks in advance for your help.
Rafal.
Distinguished Contributor
cgay
Message 2 of 2 (146 Views)
Re: Transaction & db.ObjectModified event - problems
02-24-2006 07:16 AM in reply to: rafal.watroba
rafal,
Hmmm....I remember seeing this error also at one point, but for the life of me I can't quite remember how I fixed it. But you could try something like this.....
For VB.Net 2003......
[code]
Public Shared Sub OnObjectModified(ByVal sender As System.Object, ByVal e As Autodesk.AutoCAD.DatabaseServices.ObjectEventArgs)
If TypeOf sender Is Database Then 'Only try to cast a Database object
Try
Dim db As Database = DirectCast(sender, Database)
Try
Dim trans As Transaction = db.TransactionManager.StartTransaction
Try
trans.Commit() 'Commit if no error
Catch ex As Exception
trans.Abort() 'Abort if there is an error
Finally
trans.Dispose()
End Try
Finally
db.Dispose()
End Try
Debug.WriteLine(String.Format("Unhandled exception: {0}", ex.ToString))
End Try
Else
Debug.WriteLine(String.Format("OnObjectModified Unhandled Type: {0}", TypeName(sender).ToString))
End Sub
[/code]
For VB.net 2005.......
[code]
'If trycast fails, db will be nothing
Dim db As Database = TryCast(sender, Database)
If db IsNot Nothing Then
Try
''Using' construct calls object.dispose automatically
Using trans As Transaction = db.TransactionManager.StartTransaction
Try
End Try
End Using
Finally
db.Dispose()
End Try
Else
End Sub
[/code]
Good Luck,
C
You are not logged in.
Announcements
Need installation help?
Ask the Community
