.NET
Trans Function in .net
1 REPLY 1
Giri_kani
461 Views, 1 Reply
(vlax-3d-point (trans point3d 1 0))
I want to insert a block using the above mentioned point in .net..
How to get the 3d point from the above metioned line in .net?
Please guide me if you know
1 REPLY 1
StephenPreston
in reply to: Giri_kani
Editor.CurrentUserCoordinateSystem returns the transformation matrix between WCS and UCS. Once you have that, you can transform your Point3d to the new coordinate system by passing the matrix to the Point3d.TransformBy method. You'll find a few examples of CurrentUSerCoordinateSystem if you google for it.
Cheers,
Stephen Preston
Autodesk Developer Network
”Boost
