Is there a way to use an image resource as a toolbar button image? I'm struggling with getting a file path to use. I'd really like to store my images in my dll. I can get a uri, however still can't get the file path.
Any pointers? I feel like this should be easy and I'm missing something obvious 🙂
Thanks in advance for the help!
Jerri
No. Toolbar button images must be stored in image files or in a resource-only DLL.
If I store them in a resource only dll, how would I get the file path of the image resource in order to use it with the SetBitmaps method?
SmallBitmapName = "c:\images\16x16.bmp"
LargeBitmapName = "c:\images\32x32.bmp"
newToolBarButton.SetBitmaps(SmallBitmapName, LargeBitmapName)
You use the name of the resource in place of the filename.
I'm pretty sure all of this is covered in the customization docs.
Thanks for trying to help, however I'm not sure we're talking about the same thing or it's that I'm still not getting it. I'm attempting to use a .NET resource in my project as a bitmap for a toolbar button. My problem is that SetBitmaps only takes a string path to the image, which I'm unable to get for my image resource. Also, I don't know which customization docs you are referring to??
You cannot use a .NET resource to store toolbar bitmaps.
You can only use a resource-only DLL, which contains native Win32
resources, not .NET resources.
