.NET
Speed_CAD
214 Views, 3 Replies
ToolPalete
Hi...
I have a routine in Visual Basic 2005, it is a DLL. I load it with NETLOAD command. The routine changes width of a polyline, but doesn't refresh the polyline when I change the value in the ToolPalete, it refreshes when I move the mouse over screen.
how can I make refresh when I change the value in the ToolPalete?
Thank you...
Mauricio Jorquera
3 REPLIES 3
in reply to: Speed_CAD
What version cad are you using, and what method are you trying to use to refresh the polyline.
Dan
Speed_CAD
Hi...
I'm using AutoCAD 2007, I'm just changing the value of ConstantWidth propertie, then I move the mouse over the screen I just then it refreshes. I want it to refresh when I change the value.
Mauricio Jorquera
Sounds like you just need to make a event reactor to update the drawing.
Dan
”Boost
