.NET
.NET
hassanhafeez33
Message 1 of 4 (258 Views)
Too much CPU and Memory usage. Too slow results.
258 Views, 3 Replies
10-11-2011 08:33 AM
Hello people. Its good to be back after a month of daily programming.
I have made a professional application for autocad from ground up. It achieves the aims of sorting crossections of roads.
The only problem with the code is inside one routine which has to take the empty graph in a drawing and make multiple copies of it.  The code is attached in the attachment.
For some reason, the routine takes almost more than 4 minutes to finish. There are almost 1600 objects that it has to copy and move for about ten times.
My question is, Is there a way to move the graph as a single object. As in, all the objects in the graph behaving as one object?
Any help would be greatly appreciated. N.B I have had quite a lot of fun developing the app, although Im an electronics engineer :smileyvery-happy:
acDoc.Editor.WriteMessage(vbLf & "This is time to select the main graph window")
                    Dim graphprompt As PromptSelectionResult
                    graphprompt = acDocEd.GetSelection
                    If graphprompt.Status = PromptStatus.OK Then
                        Dim Graph = graphprompt.Value
                        Dim graphobjidcoll = New ObjectIdCollection(Graph.GetObjectIds())
                        Dim count1
                        Dim x1 = 210
                        For count1 = 0 To graphsneeded
                            For Each graphobjid As ObjectId In graphobjidcoll
                                Dim obj As DBObject = trans.GetObject(graphobjid, OpenMode.ForRead)
                                Dim objclone As Entity
                                objclone = obj.Clone()
                                objclone.SetDatabaseDefaults()
                                objclone.TransformBy(Matrix3d.Displacement(New Vector3d(x1, 0, 0)))
                                acBlkTblRec.AppendEntity(objclone)
                                trans.AddNewlyCreatedDBObject(objclone, True)
                                db.TransactionManager.QueueForGraphicsFlush()
                                obj.Dispose()
                            Next
                            x1 = x1 + 210
                        Next
                        graphobjidcoll.Clear()
                    End If
Board Manager
StephenPreston
Message 2 of 4 (240 Views)
Re: Too much CPU and Memory usage. Too slow results.
10-11-2011 11:22 AM in reply to: hassanhafeez33
Skimming your code, I have two quick comments:
As a general rule, it is risky to perform a shallow clone of an entity (DBObject.Clone). Its better to use the appropriate DeepClone or WblockClone methods. As you're copying a set of entities within the same database, have you tried using Database.DeepCloneObjects with your ObjectIdCollection, instead of iterating the collection and cloning one-by-one? That may be faster.
And I'm not sure why you want to call QueueForGraphicsFlush for every iteration of the inner loop - that looks like an unnecesary call to me. I'm not familiar with how that method is implemented, but it could account for a lot of CPU overhead in your routine.
Cheers,
Stephen Preston
Autodesk Developer Network
hassanhafeez33
Message 3 of 4 (237 Views)
10-11-2011 11:33 AM in reply to: StephenPreston
Hi Stephen,
Thanks alot for ur reply.
I was not exactly sure earlier what is the difference between deepclone and simple object clone. I guess I am going to take a look into it now.
Quefor graphics flush is just to see the moved objects before the transaction is committed. Ofcourse I do not need it in every loop. Thanks for pointing that out.
And Ill take a look into Database.deepcloneobjects as well.
Thanks a lot for your help. I'm just an electronics engineer spending some time with my father's business doing some programming for him.
Cheers,
Hassan.
hassanhafeez33
Message 4 of 4 (188 Views)
10-15-2011 03:58 AM in reply to: StephenPreston
Thanks for suggesting the removal of QueForGraphicsFlush(), Stephen.
It really improved the performance a lot.
Hassan Hafeez.
