.NET
Tony T's CommandLine.vb and Boundary Command
1 REPLY 1
josephparker
571 Views, 1 Reply
args = New System.Collections.ArrayList
args.Add("-boundary")
apt = New Point2d(pt(0), pt(1)) ' pt is initialised with GetPoint
args.Add("A")
args.Add("O")
args.Add("P")
args.Add(" ")
args.Add(" ")
args.Add(apt)
args.Add(" ")
args.Add(" ")
CommandLine.Cmd(args)
this code wont progress as error Invalid Option Keyword is returned
How do you add a vbCr using Tony's CommandLine.vb
1 REPLY 1
in reply to: josephparker
The conventions are exactly the same as the conventions
used in the LISP (command) function, so you use an empty
string for ENTER.
Try this:
{code}
Dim myPoints(2) As Point3d
myPoints(0) = New Point3d(2, 2, 0)
myPoints(1) = New Point3d(4, 4, 0)
Dim args As New ArrayList()
args.AddRange(New String() {"_-BOUNDARY", "_A", "_O", "_P", ""})
args.AddRange(myPoints)
args.Add("")
{code}
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6301559@discussion.autodesk.com...
args.Add("A")
args.Add("O")
args.Add("P")
args.Add(" ")
args.Add(" ")
args.Add(apt)
args.Add(" ")
args.Add(" ")
”Boost
