Is it possible to do Thematic based on attribution display for a layer.
For eg: I have a layer called CIty with object data for name, country, etc. I would like to display a common symbol for all city points in ASIA, a different symbol or color for others etc. how can it be done with autocad.
thanks.
what product do you have as base? If you have AutoCAD Map3D (or AutoCAD Civil3D that includes the Map-functionality) then you can do that without development.
If you have plaine AutoCAD, then scan through the symbols, evaluate the attribute you have reserved for the continent (I would better us a polyline with the continent-border and look if the point-symbol is inside in what continent) and then use a block-insert with the symbol you like.
As I don't think you wanted anyone to write this now for you (for free), I guess your question was just the workflow, or are there any detailed questions open? If so, ask for these (with a more detailed question) 😉
HTH, - alfred -
hi,
The product is AutoCAD Map3D.
I want it to be displayed the image above. I do not know from where to start with. hence trying to google out some help and also posted the same here.
If it could be elaborted as how it can be done, I could try it out.
Ok, if I would have read your initial post more exactly I would have recognized the word "objectdata" so, yes, it was clear
The would be the way without development, just use standard Map3D-functionality (FDO):
- alfred -
With SHP connection, I am able to display the Thematic styles.
But I would like to do this for dwg file with object data attached. Is it possible? Do I need to create to create some form type interface and do some similar coding ?
Thanks.
