• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Valued Contributor
    The best way to remove duplicate points from DB
    132 Views, 3 Replies
    01-15-2013 11:49 PM
    ObjectARX 2007 with C#
    What would be the best way to remove duplicate points from DB?
    I do not think iterating through the whole database and compare each point's coordinate would be the best way since it will take a lot of time if the points are many.
    I once saw a CAD command that does it for me. (which I can't remember now)
    Maybe I could use that command.
    Always Thank you for your help.
    Please use plain text.
    Moderator
    Alexander.Rivilis
    Re: The best way to remove duplicate points from DB
    01-16-2013 01:14 AM in reply to: dynamicscope
    dynamicscope wrote:
    ...I once saw a CAD command that does it for me. (which I can't remember now)
    Overkill
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    Valued Contributor
    01-16-2013 06:04 PM in reply to: Alexander.Rivilis
    Unfortunately, it looks like ExpressTool supports "overkill."
    I need to cover even the version without ExpressTool.
    By the way, I found the command.
    It was "mapclean" in AutoCAD 2010 Civil 3D (not sure non-Civil 3D also has that command).
    But AutoCAD 2007 does have "mapclean" command. :smileysad:
    Looks like I have to manually implement the function?
    Moderator
    Alexander.Rivilis
    01-17-2013 02:31 AM in reply to: dynamicscope
    Yes.
