.NET
Valued Contributor
dynamicscope
Message 1 of 4 (304 Views)
The best way to remove duplicate points from DB
304 Views, 3 Replies
01-15-2013 11:49 PM
ObjectARX 2007 with C#
What would be the best way to remove duplicate points from DB?
I do not think iterating through the whole database and compare each point's coordinate would be the best way since it will take a lot of time if the points are many.
I once saw a CAD command that does it for me. (which I can't remember now)
Maybe I could use that command.
Always Thank you for your help.
Moderator
Alexander.Rivilis
Message 2 of 4 (297 Views)
Re: The best way to remove duplicate points from DB
01-16-2013 01:14 AM in reply to: dynamicscope
dynamicscope wrote:
...I once saw a CAD command that does it for me. (which I can't remember now)
Overkill
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
Valued Contributor
dynamicscope
Message 3 of 4 (277 Views)
01-16-2013 06:04 PM in reply to: Alexander.Rivilis
Unfortunately, it looks like ExpressTool supports "overkill."
I need to cover even the version without ExpressTool.
By the way, I found the command.
It was "mapclean" in AutoCAD 2010 Civil 3D (not sure non-Civil 3D also has that command).
But AutoCAD 2007 does have "mapclean" command. :smileysad:
Looks like I have to manually implement the function?
Moderator
Alexander.Rivilis
Message 4 of 4 (265 Views)
01-17-2013 02:31 AM in reply to: dynamicscope
Yes.
You are not logged in.
Ask the Community
