Hi all,
I want to temproarily adjust the snap mode to nearest only.
Dim sval As String = Application.GetSystemVariable("OSMODE")
sval = "4133"
I know can change this variable using Application.SetSystemVariable("OSMODE", Val) but have no idea what value to change it to.
Rather than troubling the forum, is there some reference I should be looking at for this sort of thing?
Solved by Alfred.NESWADBA. Go to Solution.
the easiest way is to change the obectsnap in the osnap-settings-dialog to what you want to be, close the dialog and look to the sysvar OSMODE. 😉
And in the help you can also see the details for OSMODE >>>here<<<
- alfred -
Hi Alfred,
Thanks again.
Application.SetSystemVariable("OSMODE", 512)
I don't know how this works but hope you get paid for your time here!!
