.NET
amitk_189
Message 1 of 3 (111 Views)
Task Scheduling
111 Views, 2 Replies
08-06-2012 02:36 AM
Am trying to extract data out of AutoCAD Specific drawing at a particular date and time. And this project am doing from quite long time. But the problem is how can i specify time and date to autocad and at that particular time it has to extract data. My current code is in VB.net where i am manually specifying the file, yet its taking the autocad template as its source
Dim Files() As String
Dim Path As String = "D:\Cad Drawings"
Dim DiffClass As New Class1
Dim acDocMgr As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
Dim CurrentFileCount As Integer = 0
Files = Directory.GetFiles(Path, "*.dwg", SearchOption.AllDirectories)
For i As Integer = 0 To Files.Length - 1
Dim CurrentFile As String = Files(i)
If CurrentFile.Contains("Drawing") Or CurrentFile.Contains("DWG") Then
If CurrentFile.Substring(CurrentFile.LastIndexOf(".") + 1) = "dwg" Then
acDocMgr.Open(CurrentFile, False)
Till here i do operation and at certain time i open dwg and extract data.
Is there any option to do so.
With Warm Regards
Amit
ADN Support Specialist
Balaji_Ram
Message 2 of 3 (74 Views)
Re: Task Scheduling
08-09-2012 05:31 AM in reply to: amitk_189
Hi Amit,
Your question is not very clear.
What do you mean by "extracting data at a particular date and time" ?
Balaji
Developer Technical Services
Autodesk Developer Network
Valued Mentor
Message 3 of 3 (70 Views)
Re: Task Scheduling
08-09-2012 07:22 AM in reply to: amitk_189
May be you can add a trigger on some of the save database events (BeginSave or SaveComplete), and set the autosave to a given period, but this need another monitor on the Autosave variable (SAVETIME) in order to avoid user changes.
Gaston Nunez
You are not logged in.
Ask the Community
