.NET
TRUSTEDPATHS FOR "HEKY_LOCAL_MACHINE"
4 REPLIES 4
Amremad
1114 Views, 4 Replies
Hello every one
i know how can i put my dll in Trusted Paths for current user
but i don't know how can i put it for all user in  HEKY_LOCAL_MACHINE
any help
4 REPLIES 4
Amremad
in reply to: Amremad
any solution
Balaji_Ram
The registry keys for storing them are :
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R19.1\ACAD-D000\Variables\TRUSTEDDOMAINS
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R19.1\ACAD-D000\Variables\TRUSTEDPATHS
The other way is to create a bundle and place it in the
%ProgramData%\Autodesk\ApplicationPlugins. The ApplicationPlugins folder is automatically trusted.
Balaji
Developer Technical Services
Autodesk Developer Network
Amremad
in reply to: Balaji_Ram
Mr. Balaji_Ram , thanks for help
but did you test this path:
i know this path and i tested it before , but doesn't work .
i will test "%ProgramData%\Autodesk\ApplicationPlugins." , and i will tell you the result after testing
Amremad
i tested "%ProgramData%\Autodesk\ApplicationPlugins.", and it's work good
thank you very much Mr. Balaji_Ram
”Boost
