.NET
Switching layouts with .NET
1 REPLY 1
ti
225 Views, 1 Reply
I have a simple form with a combobox that I fill with all layout names ;
_
Public Sub sm()
Dim fmain As New main
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
Dim db As Database = HostApplicationServices.WorkingDatabase
Dim tr As Transaction = db.TransactionManager.StartTransaction()
Dim bt As BlockTable = tr.GetObject(db.BlockTableId, OpenMode.ForRead)
fmain.LayoutBox.Items.Clear()
For Each btrid As ObjectId In bt
Dim btr As BlockTableRecord = tr.GetObject(btrid, OpenMode.ForRead)
If btr.IsLayout Then
Dim lo As Layout = tr.GetObject(btr.LayoutId, OpenMode.ForRead)
fmain.LayoutBox.Items.Add(lo.LayoutName)
End If
Next
fmain.Show()
End Sub
I want to switch layouts from my combobox when the selectedtext changes, the following code doesn't seem to work ;
LayoutManager.Current.CurrentLayout = LayoutBox.Text
Can anyone help ?
1 REPLY 1
in reply to: ti
Well, this code has worked for me in the past:
Dim lMan As LayoutManager = LayoutManager.Current
lMan.CurrentLayout = LayoutBox.Text
Is the code you pasted in a button click event on the form? If so, this could be the probem. Try adding a Sub in the main class with a command method. I always do this anyway, and the forms only send strings to execute to the drawing. That way, the user has the option of using the command line instead of the UI you provide - but in your case this may not be a viable solution.
”Boost
