.NET
New Member
rtonin
Message 1 of 1 (303 Views)
SummaryInfo c#
303 Views, 0 Replies
07-19-2005 04:45 AM
I have wrote this class to read/write summaryInfo for a drawing
public class AutoCADDocumento
private Autodesk.DatabaseServices.DatabaseSummaryInfoBuilder m_prop;
public AutoCADDocumento()
private void BeginEditCustomProperties()
m_prop = new DatabaseSummaryInfoBuilder(Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.SummaryInfo);
private void EndEditCustomProperties()
int i = m_prop.CustomProperties.Count;
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.SummaryInfo = m_prop.ToDatabaseSummaryInfo();
m_prop = null;
public bool Codifica()
this.BeginEditCustomProperties();
m_prop.Title = "Test di prova";
this.EndEditCustomProperties();
return true;
when i create an istance of this class and i call the method Codifica I receive an elockviolation exception with this stack:
at Autodesk.AutoCAD.Runtime.Interop.ThrowExceptionForErrorStatus(Int32 errorStatus)
at Autodesk.AutoCAD.Runtime.Interop.Check(Int32 returnValue)
at Autodesk.AutoCAD.DatabaseServices.DatabaseSummaryInfo.CopyToUnmanagedObject(IntPtr unmanagedPointer)
at Autodesk.AutoCAD.DatabaseServices.Database.set_SummaryInfo(DatabaseSummaryInfo value)
at Idroesse.IdroesseNETWinForms.AutoCAD.AutoCADDocumento.EndEditCustomProperties() in d:\idroessenet\idroessenetaddin\idroessenetwinforms\classi\autocad\autocaddocumento.cs
if i open the Drawing Property Dialog in AutoCAD I found the Title property unchanged (empty)
What can i do?
You are not logged in.
Announcements
Need installation help?
Ask the Community
