.NET
matus.brlit
Message 1 of 5 (211 Views)
Storing data in ResultBuffer
211 Views, 4 Replies
03-28-2013 12:35 AM
When storing data in ResultBuffer, I found, that there are DxfCodes, that seem to have the same meaning.
DxfCode.ExtendedDataAsciiString Vs. DxfCode.Text
DxfCode.ExtendedDataInteger16 Vs. DxfCode.Int16
Can anyone clarify if there is any difference between them?
Moderator
Alexander.Rivilis
Message 2 of 5 (193 Views)
Re: Storing data in ResultBuffer
03-28-2013 02:27 AM in reply to: matus.brlit
DxfCode.ExtendedDataXXXX can be used only as a part of extended data (http://through-the-interface.typepad.com/through_the_interface/2007/04/adding_xdata_to.html)
Пожалуйста не забывайте про Утвердить в качестве решения! Утвердить в качестве решения и Give Kudos!Баллы
Please remember to Accept Solution! Accept as Solution and Give Kudos!Kudos
matus.brlit
Message 3 of 5 (189 Views)
03-28-2013 02:45 AM in reply to: Alexander.Rivilis
So in XData, I can use whichever I want, but elsewhere, I have to use DxfCode.Text and DxfCode.Int16 ? And where is that elsewhere? Because when storing data in XRecords, they are stored in the XRecortd's Data property, which is the same.
Maybe for communication with Lisp?
Moderator
Alexander.Rivilis
Message 4 of 5 (176 Views)
03-28-2013 03:40 AM in reply to: matus.brlit
1. In XData you can not use DxfCode.Text and DxfCode.Int16 but can use DxfCode.ExtendedDataAsciiString and DxfCode.ExtendedDataInteger16
2. In XRecord you can use DxfCode.Text and DxfCode.Int16
matus.brlit
Message 5 of 5 (168 Views)
03-28-2013 03:48 AM in reply to: Alexander.Rivilis
Thanks for clarification.
You are not logged in.
Ask the Community
