I'd like to know if it's possible to attach custom data to my DST files (for sheet set manager) much the same as I can attach custom data to my dwg files.
There is an extension that I'd like to write that will read and write the DST files but some of the custom work that the extension does will need to be stored somewhere specific to each DST file and I'd rather not have to create a separate file.
Also I'd like the extension to be able create/edit the DST file without starting ACAD editor (as far as the user is concerned, the extension would be the only thing running).
Don Ireland
Engineering Design Technician
ShhetSet file is just a xml file with substitution cipher.
http://www.theswamp.org/index.php?topic=46497.0
