.NET
Split Arc into Lines
4 REPLIES 4
tasaq313
1404 Views, 4 Replies
I've got a code that creates a convex hull from polyline vertices, but if polyline contains arc segment I've got the wrong results. Is there any way to convert arc into several lines using C# API?
Built in command that I would like to mimic is called 'flatten'.
4 REPLIES 4
mcicognani
in reply to: tasaq313
You may analyze the polyline segments and collect vertex points. When you get a CircularArc2d segments, you may use GetSamplePoints() to retrieve a number of points that you can add to the list and later use to create your hull.
BKSpurgeon
HI any chance you code post the convex hull code - i'm sure future users will be thankful
rgds
BK
SENL1362
in reply to: BKSpurgeon
"You'll need Gile" for a solution of these type of problems 🙂
http://www.theswamp.org/index.php?topic=31865.0
BKSpurgeon
in reply to: SENL1362
Yes it is brilliant. thanks to you and Gile. you are right. he is a grandmaster virtuoso.
”Boost
