.NET
Distinguished Contributor
SRSDS
Message 1 of 10 (365 Views)
Spline Length
365 Views, 9 Replies
05-20-2013 03:04 PM
Is there a way to determine the length of a spline?
Valued Mentor
Message 2 of 10 (355 Views)
Re: Spline Length
05-20-2013 04:03 PM in reply to: SRSDS
Look here: Curve Length , and also here: Quirky Polylines for more enlightenment.
Gaston Nunez
Valued Mentor
Message 3 of 10 (351 Views)
Re: Spline Length
05-20-2013 04:47 PM in reply to: gasty1001
Hi Gasty, the code at the first link you referenced is not terribly robust. It will fail on curves that have no length (e.g., Rays and XLines), and assumes that the caller is passing the result of the 'as' operator to cast the object to a Curve, but not retaining the reference to the Curve (or having to do that again), and it doesn't leverage extension methods.
This extension method will return a bool to indicate if the a length was acquired, or false if not, and will set the result parameter to the curve's length.  You can use this method on any Curve without it throwing an exception, but you should still filter those types that consistently do not produce a result (like Rays and XLines), to avoid the higher cost of having to catch many thrown exceptions.
public static class CurveExtensions
   public static bool TryGetLength( this Curve curve, out double result )
      try
         result = curve.GetDistanceAtParameter( curve.EndParam ) -
            curve.GetDistanceAtParameter( curve.StartParam );
         return true;
      catch( Autodesk.AutoCAD.Runtime.Exception )
         result = 0.0;
         return false;
Valued Mentor
Message 4 of 10 (343 Views)
Re: Spline Length
05-20-2013 05:34 PM in reply to: DiningPhilosopher
Hi Tony,
You are right, just had the link to spiderman in my references without checking. Nice way to go with that Tony.
Gaston Nunez
*Expert Elite*
Alfred.NESWADBA
Message 5 of 10 (307 Views)
Re: Spline Length
05-21-2013 11:13 AM in reply to: DiningPhilosopher
May I ask what condition has to exist that this calculation will result in a value n.e. 0.0?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Valued Mentor
Message 6 of 10 (302 Views)
Re: Spline Length
05-21-2013 12:09 PM in reply to: Alfred.NESWADBA
Try calling it on an Arc whose start angle is != 0.0
*Expert Elite*
Alfred.NESWADBA
Message 7 of 10 (299 Views)
Re: Spline Length
05-21-2013 12:32 PM in reply to: DiningPhilosopher
Well, tried, my result is 0.0 as you can see in the screenshot (that shows the debug-info from an arc with start-angle and end-angle != 0.0)
- alfred -
Alfred NESWADBA
Valued Mentor
Message 8 of 10 (271 Views)
Re: Spline Length
05-21-2013 07:06 PM in reply to: Alfred.NESWADBA
It is the StartParameter that is not always 0.0.
The result of GetDistanceAtParameter() with the curve's start parameter is usually 0.0, but I have seen cases where it isn't, which involved custom objects derived from AcDbCurve, that return a non-zero value, and getting the actual length requires the algorithm shown, so it is designed to ensure that the actual distance is calculated, even if the distance at the start parameter is non-zero, which is an assumption I don't recommend relying on if dealing with custom objects.
*Expert Elite*
Alfred.NESWADBA
Message 9 of 10 (267 Views)
Re: Spline Length
05-21-2013 07:45 PM in reply to: DiningPhilosopher
That was my question, when this result gives != 0.0.
So the arc you suggested does return 0.0 for you too?
In that case the custom objects returns a wrong value. And if it returns a defect length at the startparam I also would not trust any other calculation returned by GetDistanceAtParameter(), so also for the endparam. With other words the length calculation in that case might be wrong anyway and not to be trusted.
At least I never have seen that this return not 0.0 and so I'm wondering about that calculation within your function.
- alfred -
Alfred NESWADBA
Valued Mentor
Message 10 of 10 (263 Views)
Re: Spline Length
05-21-2013 08:00 PM in reply to: Alfred.NESWADBA
- alfred -
No, actually I mistakenly thought you were asking about the value of the StartParameter, which is non-zero for arcs and some other objects.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
