I am trying to set the text style of a DBText object.
The following code fails when it gets to the line where I try to set the text style (this is done using VB.NET 4.0 and AutoCAD 2012 64-bit).
Error reads as follows:
Method not found: 'Void
Autodesk.AutoCAD.DatabaseServices.DBText.set_TextStyle
(Autodesk.AutoCAD.DatabaseServices.ObjectId)'.
Code:
Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
Dim acCurDb As Database = acDoc.Database
Using acLockDoc As DocumentLock = acDoc.LockDocument
Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction
Dim acBlkTbl As BlockTable = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
Dim acBlkTblRec As BlockTableRecord = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
Dim acTxtStylTbl As TextStyleTable = acTrans.GetObject(acCurDb.TextStyleTableId, OpenMode.ForRead)
Dim sStyleName As String = "STANDARD"
If acTxtStylTbl.Has("STYLENAME") Then
sStyleName = "STYLENAME"
Dim acText As New DBText
acText.SetDatabaseDefaults()
acText.TextStyle = acTxtStylTbl(sStyleName)
acText.TextString = "Some Text Here"
acText.Height = 12
acText.Position = New Point3d(0,0,0)
acText.HorizontalMode = TextHorizontalMode.TextCenter
acText.VerticalMode = TextVerticalMode.TextVerticalMid
acText.AlignmentPoint = New Point3d(0,0,0)
acBlkTblRec.AppendEntity(acText)
acTrans.AddNewlyCreatedDBObject(acText, True)
acTrans.Commit()
End Using
End Using
Thank in advance for any information,
Scott
try
acText.TextStyleID = acTxtStylTbl(sStyleName)
HTH, - alfred -
Please disregard the previous post. I forgot I was referencing AutoCAD 2009 dll files (the version the users of this current proeject are running) and was trying to test the project in AutoCAD 2012.
Sorry,
Scott
So I understand that this is a VERY old post; however I thought I would add an answer here for ACAD 2020 since this has gone unanswered.
First I would suggest making a check for the style; I did this in a separate function as so it could create the style with some default settings if the TextStyle does not exits
Shared Function GetTextSyleRecord(StyleName As String) As TextStyleTableRecord Dim SubStacktrace As StackTrace = New StackTrace(New StackFrame(True)) UpdateTrans() Dim ts As TextStyleTableRecord Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() Dim st As TextStyleTable = CType(acTrans.GetObject(acCurDb.TextStyleTableId, OpenMode.ForRead, False), TextStyleTable) If st.Has(StyleName) Then Debug_Msg(SubStacktrace, $"Textstyle '{StyleName}' exist; casting object to TextStyleTableRecord", Debug_Debug) Dim obj As ObjectId = st.Item(StyleName) ts = acTrans.GetObject(st.Item(StyleName), OpenMode.ForRead) Else Debug_Msg(SubStacktrace, $"Textstyle '{StyleName}' does not exist; creating style", Debug_Warning) Dim acTextStyleTblRec As TextStyleTableRecord = acTrans.GetObject(acCurDb.Textstyle, OpenMode.ForWrite) Dim acFont As Autodesk.AutoCAD.GraphicsInterface.FontDescriptor = acTextStyleTblRec.Font st.UpgradeOpen() ts = New TextStyleTableRecord With { .Name = StyleName, .TextSize = 0.25, .Font = New Autodesk.AutoCAD.GraphicsInterface.FontDescriptor("Swis721 BT", False, False, Nothing, Nothing) } st.Add(ts) acTrans.AddNewlyCreatedDBObject(ts, True) End If acTrans.Commit() End Using Return ts End Function
Next a function to insert new text at a given point (Note you need to set the text height to the styles text height, I assumed it would do this since it knows what style it is to follow but it does not)
Shared Function InsertText(ByVal InsertPoint As Point3d, ByVal Txt As String, ByVal TextStyle As String) As Boolean UpdateTrans() 'lookup text style Using acDoc.LockDocument() Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction() Dim acBlkTbl As BlockTable = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) Dim acBlkTblRec As BlockTableRecord = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite) Dim TextStyleRec As TextStyleTableRecord = GetTextSyleRecord(TextStyle) Using acText As DBText = New DBText() acText.Position = InsertPoint acText.TextString = Txt acText.Height = TextStyleRec.TextSize acText.TextStyleId = TextStyleRec.ObjectId acBlkTblRec.AppendEntity(acText) acTrans.AddNewlyCreatedDBObject(acText, True) End Using acTrans.Commit() End Using End Using Debug_MarkTimingFunction(SrcStack, New StackTrace(New StackFrame(True)), stopWatch, "finished proccess") Return True End Function
my 'UpdateTrans' function just makes sure my module variables for the document are point correct so I dont have to keep redefining them over and over for every possibly new transaction for newly opened document
Shared Function UpdateTrans(Optional ByVal Doc As Document = Nothing) As Boolean Try If IsNothing(Doc) Then acDoc = Application.DocumentManager.MdiActiveDocument Else acDoc = Doc End If acCurDb = acDoc.Database acEditor = acDoc.Editor Catch ex As Exception Return False End Try Return True End Function
Hope this helps the next person to stumble across this post.
