I am using VB.net with AutoCAD at the moment
in VB.net I created an AutoCAD for opening lots dwg files( over 1000 maybe more ) and insert text or graphic.
User will run this program as background thread, like virus scan.
The problem is
If I set my AutoCAD object as Single drawing compatibility=false, the temp log file (for AutoCAD ) will have error(exceed the max size)
If I set compatibility=true. there will be lots application busy exception thrown out in VB.net
How can I solve the problem?
Thanks a lot
