Hi
i have and autocad 2011 addin which download a drawing from internet and open it in autocad.
i am using a web browser control on a win form to display a webpage from where i am downloading my drawing. it is working fine on xp 32bit.
During testing on Windows 7 64bit after some time i m unable to see my form when i click open button on ribbon.
Showdialog() call from button only display the icon and title of my form in windows taskbar but Form is not visible on the screen.
i tried the Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog no luck.
only solution to make it work again is to remove my windows profile and create it again.
i cant understand the problem please help.
i am using VS2010 and C# with Autocad 2011.
thanks
nav
Solved by mnav. Go to Solution.
are you sure it's not just the display-order, so your dialog hides behind AutoCAD? I've got troubles when I changed to Win7, the ZOrder does not work automatically bringing dialogs on top. So now I use .BringToFront multiple times to ensure it's in front of other applications.
- alfred -
Can I ask if the application code is yours?
Does the form you are trying to show have ShowInTaskbar = True
When you expect the ShowDialog to execute, is the form in the task bar?
all you need in the code is Form.ShowDialog(), at which point control remains in the form and the code will not continue to execute. Have you tried debugging and see whether in fact you even get to this statement?
Good luck.
Can I assume that the Form.ShowDialog is not yours, and so you can't step through it?
If the code for the form is there, you should be able to step through it as well.
ShowDialog is my own code which calling System.windows.Forms.Form showdialog. i can step into it form load event get called but no form on the screen.
have you looked to the property "ShowInTaskbar" as stuartnathan already mentioned, turn it on and then look if you see the form in the taskbar.
- alfred -
Thanks everybody for ther help solved the issue
i was recording the last position of the dialog on the screen. when i was closing the dialog from taskbar when its window not visible which is win7 feature it was recording the location and next time try to use that position to display form which was not valid location.
thanks
