.NET
Valued Contributor
GrzesiekGP
Message 1 of 7 (756 Views)
Show WinForm with ProgressBar while doing job in command.
756 Views, 6 Replies
08-27-2012 01:03 AM
Hello!
I've some function in my command which calculating lots of data on dwg file.
I would like to show to user a WinForm with progress value. From the command I'm incrementing value of ProgressBar.
The problem is that my ProgressBar is incrementing to the 100% after done all the job - suddendly.
I think I can use some threading or backgroundWorker but it's hard for me and I didn't find any examples.
Can anyone help me?
Thanks.
norman.yuan
Message 2 of 7 (735 Views)
Re: Show WinForm with ProgressBar while doing job in command.
08-27-2012 06:44 AM in reply to: GrzesiekGP
It simple and straightforwaord approch of showing progress bar on a form is to move the long processing logic into Form's code behind. However, this reduces code maintenanbility because it mixes the UI and data process code. This post might be useful to you:
http://drive-cad-with-code.blogspot.ca/2010/12/showing-progress-window-when-running.html
ADN Support Specialist
augusto.goncalves
Message 3 of 7 (693 Views)
08-30-2012 07:44 AM in reply to: GrzesiekGP
AutoCAD has a built-in progress bar feature, have you looked at that?
http://through-the-interface.typepad.com/through_the_interface/2007/05/displaying_a_pr.html
Augusto Goncalves
Autodesk Developer Network
matus.brlit
Message 4 of 7 (681 Views)
08-30-2012 12:03 PM in reply to: GrzesiekGP
if you don't need the UI to be responsive during the process (you don't have a Stop button, for example) then the easiest approach is moving the calculation to the UI thread
If you need the UI to be responsive, then look at this class http://msdn.microsoft.com/en-us/library/system.componentmodel.backgroundworker.aspx but don't forget to create thread-safe method for incrementing the progress bar.
Active Contributor
MGOMKD
Message 5 of 7 (649 Views)
09-03-2012 07:09 AM in reply to: matus.brlit
I have just done what you want and it works!
First you have to init the min and max value of your ProgressBar, for instance iMin=0 and iMax=object.count
Then in your loop just add a line which increment the i value of the ProgressBar.
 And the most essential is to upgrade your active form with the "Refresh" method.
For instance:
'ProgressBar init'
Dim iMin As Long = 0
Dim iMax As Long
'Object Count'
Using acTrans = acDocs.MdiActiveDocument.Database.TransactionManager.StartTransaction()
      acBlkTbl = acTrans.GetObject(acDocs.MdiActiveDocument.Database.BlockTableId, OpenMode.ForRead)
      acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForRead)
      For Each acObjId As ObjectId In acBlkTblRec
          imax=iMax+1
      Next acObjId
End Using
ProgressBar1.Minimum= iMin
ProgressBar1.Maximum= iMax
'Iterate Through objects'
Dim i as Long
          'Your code'
          i=i+1
          ProgressBar1.Value = i
          Me.Refresh 'Me=ActiveForm'
      Next acObjId
End Using
 Hope this may help you.
See you soon.
matus.brlit
Message 6 of 7 (630 Views)
09-03-2012 11:40 PM in reply to: MGOMKD
I suggest refreshing just the ProgressBar
Instead of Me.Refresh use ProgressBar1.Refresh
I had a lengthy operation and after a lot of optimalisation of the calculations, I found out, that half of the duration took the UI refreshing.
Active Contributor
MGOMKD
Message 7 of 7 (538 Views)
10-04-2012 05:46 AM in reply to: matus.brlit
Yeah! refreshing progressing bar instead of the form, is better!
See you.
You are not logged in.
Ask the Community
