.NET
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Shall I dispose Result Buffer in this sample function ?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have seen lots of samples for resultbuffer objects. And I am not quite undestand where I have to dispose and where not to. I know It doens't hurt to dispose it anyways. But I am a woman and don't like to see extra unnessary lines in my application.Everything should be perfect. So someone explain it for me. Let's say below Funciton . Do I need a dispose ? Thanks . Regards .
Function test(ByVal Myobjid As ObjectId) As Boolean
Dim MyDwg As Document = Application.DocumentManager.MdiActiveDocument
Using Tr As Transaction = MyDwg.TransactionManager.StartTransaction
Dim mydbObj As DBObject = Tr.GetObject(Myobjid, OpenMode.ForRead)
If TypeOf mydbObj Is BlockReference Then
Dim BR As BlockReference = TryCast(mydbObj, BlockReference)
If BR.IsDynamicBlock Then
Dim myrb As ResultBuffer = mydbObj.GetXDataForApplication("BlahBlah")
If myrb.AsArray(1).Value.ToString.StartsWith("TEST") Then
Tr.Commit()
Return True
End If
End If
End If
Tr.Commit()
End Using
Return False
End Function
Re: Shall I dispose Result Buffer in this sample function ?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In my opinion, yes, because it is not associated with the transaction, so your using statement will not dispose of it for you.
A bigger question for me is wether or not you should be disposing BR. mydbObj will get disposed by the using statement on your transaction, but I'm not sure about BR.
If you are using AuotCAD 2009 or later, I would suggest this:
'Dim mydbObj As DBObject = Tr.GetObject(Myobjid, OpenMode.ForRead)
'If TypeOf mydbObj Is BlockReference Then
If Myobjid.ObjectClass.Name = "AcDbBlockReference" then
Dim BR As BlockReference = Tr.GetObject(Myobjid, OpenMode.ForRead)
Using myrb As ResultBuffer = mydbObj.GetXDataForApplication("BlahBlah")
Tr.Commit()
Return True
End If
End Using
End If
End If
Tr.Commit()
End Using
Return False
End FunctionThe using statement will ensure the result buffer gets disposed wether it is your test value, or not. And using ObjectId.ObjectClass will allow you to type test for BlockReference without opening the object into memory. That is the part that only works in 2009 or later.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Chief,
I will use your code. I didn't know about "ObjectClass" that is good trick .
But still I am confused. because once I removed all " disposed " function for result buffer and nothing happened. I worked with drawing for 2 hours . No crash . Audit didn't show anything. that I why I am not sure why do I need it ? if there is a need for dispose how and where phisically it will affect ? Do you know ?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
For the most part, in my experience, not calling dispose will not cause a crash, unless you try to access the object after it falls out of scope which would cause a crash even if you did call dispose. The result of not calling dispose is that the object remains in memory, and it is not flagged for garbage collection.
My general rule to avoid that memory usage is to call dispose (or use a "using" directive) on every object that implements iDisposable, and I have even implemented iDisposable on some of my own classes. If you open an object using Transaction.GetObject(ID, openmode), then when you dispose the transaction, the object will be disposed as well, which is why you usually don't see explicit .Dispose calls on objects opened that way.
The exception to that rule is that you never call dispose on an object you didn't create. For example the active document, or the TransactionManager, or any Database that is open in the editor (unless you close it first).
If you are using Visual Studio, and you have the appropriate debug messages enabled, you will see messages in the output window that say "Forgot to call dispose?". My goal is to never see any of those messages.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks chief, It was a great explanation and now I feel more comfortable. Didn't have a clue about all these. Like a blind person walking .
Just one more question and I am done. I work with Visual studio and and don't know how to activate appropriate debug message to tell me I have to dispose. I attach the setting I have as image. Let me know please if with this setting I should see that warning you mentioned.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The settings I was referring to are in a different location, in the options dialog (which you can to as shown below, from the debug pulldown, or also from the Tools pulldown ->Options) Then you have to make sure Show All Settings is checked in the bottom left. Go to Debugging->Output Window. image shows how mine were set.
Since I didn't see an option in there that jumped out at me for the dispose messages, I fiddled around a bit, and turned all of them off. Then I tested again, and I still got my "Forgot to call dispose?" message that you see in the image. Obviously I have a missing dispose call somewhere that I need to find
But more importantly, you might not need to mess with these options because like I said, even with all of them off I still got my message.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I just noticed that if you right-click in the output window, you get direct access to toggle the "General Output Settings" plus one more called "Program Output". If you turn off Program output, pretty much everything goes away, including the Dispose messages.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Much appreciated .
I had them off. After I turned them on. I have 200 lines. My God ?!!
What did you do to me Chief ? Just Joking.
This is going to be a good weekend, finding all 200 Boo BOOs.
Thanks for all help
Janet
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Keep in mind, if you forget to dispose something that is inside a loop, you will get one of those messages for every time through the loop, so you probably don't have 200 Boo Boos to find.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm not convinced that the ResultBuffer needs to be disposed.
For Reference :
http://www.theswamp.org/index.php?topic=39724.msg4
http://www.theswamp.org/index.php?topic=27651.msg3
I'd LIKE to see some qualified direction from AutoDesk regarding this issue.
Regards
Kerry
class keyThumper<T> : Lazy<T>; another Swamper
I do not endorse the social media app links below![]()
