.NET
Setting MDIActiveDocument freezes the program
3 REPLIES 3
GeeHaa
508 Views, 3 Replies
Hi
I'm trying to switch documents and add some text. But the program switches to the document then freezes without executing any lines after switching documents.  Ive done this before without a problem. Any help would be much appreciated.
Thanks in Advance
If flyToHandle <> "" Then
                        Dim docIsopen As Boolean = False
                        For Each doc As Document In DocumentManager
                            If doc.Name = flyToDwgName Then
                                docIsopen = True
                                acdoc = doc
                                DocumentManager.MdiActiveDocument = acdoc
                        Next
                        If docIsopen = False Then
                            acdoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.Open(flyToDwgName, False)
                            Using lockDoc As DocumentLock = acdoc.LockDocument
                                Dim dsCom As DSCCommands = New DSCCommands
                                dsCom.getConnect()
                                dsCom.Init_Conn(HostApplicationServices.WorkingDatabase)
                                flyToHandle = ""
                            End Using
3 REPLIES 3
StephenPreston
in reply to: GeeHaa
Is your code running in the 'Document' context or the 'Session' context? If the former, I'd expect your code to freeze when another document became active. That's by design.
Cheers,
Stephen Preston
Autodesk Developer Network
GeeHaa
in reply to: StephenPreston
I think I'm in document context. But I'm not sure. In my previous program -The one that works, I switched documents inserted a block with attributes then swiched back to the original drawing and inserted a block with attributes. In this program I'm first adding text to the current document then switching to another drawing. when it freezes.
How do you set up for session as opposed to document context?
Thanks Very much
DiningPhilosopher
in reply to: GeeHaa
If your code is in or called from a CommandMethod that has the CommandFlags.Session flag, it runs in the ApplicationContext, otherwise it runs in the document context.
You can check by calling DocumentCollection.IsApplicationContext.
To switch documents, your code must be running in the application context, and if it modifies anything in a document it must lock the document before/after making the changes.
”Boost
