Setting Break Points
mgorecki
Message 1 of 8
mgorecki
I'm using VB.Net in Visual Studio version 2010 with AutoCad 2010.  I haven't had a problem with this before, but now it seems that the program ignores break points that I set in the code when I'm trying to debug.  I just want to pause the code and add a "watch" to a variable.
Anyone have a step by step way to do this as the msn method isn't working.
Mark
Replies (7)
Message 2 of 8
Alfred.NESWADBA
So this project was already working in the debugger?
Additional questions:
  • your project-type is a DLL (or an EXE)?
  • have you added any references that are not valid for 32bit or 64bit, whatever AutoCAD-option you have?
  • Have you made Framework 3.5 active (which would be the same as AutoCAD 2010 works with) or have you assigned 4.0?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 8
Message 4 of 8
if you have VS2010 EXpress you need to add this manualy in the 'file NameOfYouProject'.vbproj  :
    <StartAction>Program</StartAction>
    <StartProgram>c:\Program Files\AutoCAD 2010\acad.exe</StartProgram>
after the line :
  <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
and after :
  <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|AnyCPU' ">
the site http://through-the-interface.typepad.com/t......    is for a registered VS2010. so Solution 1 and 3 you cant do this.
For Solution 2 it a file in your 'C:\Program Files\AutoCAD 2010' if you have this path for autocad.
Message 5 of 8
mgorecki
Hello Alfred,
My project is a .dll.
I believe the only references I added were AcDbMgd.dll and AcMgd.dll from ObjectARX 2010, inc-x64.
As for the framework, where do I find that information?
Mark
Message 6 of 8
mgorecki
Hello Felix,
Thank you for the link, but I'm a newbie at VB.Net and I'm not sure my program is what they are talking about.  I don't see a "solution" in the Solution Explorer (see pics).
Mark
Message 7 of 8
hi mark
sorry that was a bit short - i remember that what i did at the time was what kean refers to as solution 2 and that is allocate the acad configuration file, which doesn't contain much more than kean shows, and change the version to 4.0, in my case. i think this version then needs to conform to the project's target framework: project -> project properties to open the properties tab, highlight compile, scroll down and choose advanced compile options -> set your target framework at the bottom. (i hope that will see you through)
felix
Message 8 of 8
mgorecki
Hi Felix,
I did what you did.  I copied the text from Keans site (step 2) and put it in my acad.exe.config file.  That did the trick.
Mark
