• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Contributor
    Set screen center to my point
    212 Views, 5 Replies
    08-27-2012 12:02 PM
    At this time I tried to set screen center. I have some object and I want to set screen position to this object.
    What I did:
     AcadApplication app = (AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
     using (Transaction tr = doc.Database.TransactionManager.StartTransaction())
          Entity en = (Entity)tr.GetObject(objectId, OpenMode.ForRead); // get my obj by Id
          Extents3d ext = en.GeometricExtents;
           Point3d p_center = new Point3d( // get center
                            (ext.MinPoint.X + ext.MaxPoint.X) / 2,
                            (ext.MinPoint.Y + ext.MaxPoint.Y) / 2,
                            (ext.MinPoint.Z + ext.MaxPoint.Z) / 2
         // set center point of current view
           ed.UpdateTiledViewportsInDatabase();
          ViewportTableRecord viewportTableRec = tr.GetObject(ed.ActiveViewportId, OpenMode.ForWrite) as ViewportTableRecord;
          viewportTableRec.CenterPoint = new Point2d(p_center.X, p_center.Y);
           ed.UpdateTiledViewportsFromDatabase();
       // Ok!
           tr.Commit();
      // set object as selected - it works
      doc.Editor.SetImpliedSelection(new ObjectId[] { objectId });
    I see that SetImpliedSelection works fine (as I see current object) but screen center  is moved to unknown point.
    How I can set screen center to my point?
    Pavel.
    Please use plain text.
    Hallex
    Re: Set screen center to my point
    08-27-2012 01:31 PM in reply to: pva75
    Something like this will do your work
          Matrix3d ucs = ed.CurrentUserCoordinateSystem;
           ).TransformBy(ucs);
    ~'J'~
    Active Contributor
    08-27-2012 11:04 PM in reply to: Hallex
    No changes :smileysad:
    Active Contributor
    08-27-2012 11:11 PM in reply to: pva75
    I had created new schema and this code works, but still doesn't work in old, stored file.
    It's very strange.
    It seems in old file I have very specific view but I have no idea what it is.
    Pavel.
    08-28-2012 01:56 AM in reply to: pva75
    You need to transform the Extents3d from World Coordinates System to the viewport Display Coordinates System before calculating the center point.
            private void SetViewCenterToObject(ObjectId id)
                Document doc = Application.DocumentManager.MdiActiveDocument;
                Editor ed = doc.Editor;
                using (Transaction tr = doc.TransactionManager.StartTransaction())
                using (ViewTableRecord view = ed.GetCurrentView())
                    Matrix3d DCS2WCS =
                        Matrix3d.Rotation(-view.ViewTwist, view.ViewDirection, view.Target) *
                        Matrix3d.Displacement(view.Target - Point3d.Origin) *
                        Matrix3d.PlaneToWorld(view.ViewDirection);
                    Entity ent = (Entity)tr.GetObject(id, OpenMode.ForRead);
                    Extents3d ext = ent.GeometricExtents;
                    ext.TransformBy(DCS2WCS.Inverse());
                    view.CenterPoint = new Point2d(
    (ext.MaxPoint.X + ext.MinPoint.X) / 2.0,
    (ext.MaxPoint.Y + ext.MinPoint.Y) / 2.0); ed.SetCurrentView(view); tr.Commit(); } }
    Gilles Chanteau
    Active Contributor
    08-28-2012 03:52 AM in reply to: _gile
    Wow! It works! Thanks, gile!
    Pavel.
