Set MLeader ArrowObject to Closed-Filled.
I'm testing code from Kean:
http://through-the-interface.typepad.com/through_the_interface/2007/01/creating_an_aut.html
Everything is ok, it works great.
But I have one problem. I would like to have closed-filled arrow with my MLeader, but when I send stringname = "" or "." I'm getting error about no found key.
Anyone has got some clue for me? I googled I found nothing.
AC 2007, WinXP x86, VS2010, NET 3.5
Hallex
Here is working example tested on A2010
{code}
      [CommandMethod("mldf")]
        public void MleaderTest()
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            Matrix3d ucs = ed.CurrentUserCoordinateSystem;
           object dimld= Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("dimldrblk");
            using (Transaction tr = db.TransactionManager.StartTransaction())
                try
                    Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("dimldrblk", ".");
                    Point3d arrowPoint = ed.GetPoint("\nPick a point for the arrowhead: ").Value;
                    PromptPointOptions pto = new PromptPointOptions("\nPick a point for text: ");
                    pto.UseBasePoint = true;
                    pto.UseDashedLine = true;
                    pto.BasePoint = arrowPoint;
                    Point3d symbolPoint = ed.GetPoint(pto).Value;
                    Vector3d vec;
                    if (arrowPoint.X <= symbolPoint.X)
                        vec = new Vector3d(1, 0, 0);
                    else
                        vec = new Vector3d(-1, 0, 0);
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    double th = db.Dimtxt;
                    MText mtxt = new MText();
                    mtxt.SetDatabaseDefaults();
                    mtxt.Attachment = vec == new Vector3d(1, 0, 0) ? AttachmentPoint.MiddleLeft : AttachmentPoint.MiddleRight;
                    mtxt.TextHeight = th;
                    mtxt.Width = 0.0;
                    mtxt.Contents = "Line 1\\PLine2";
                    MLeader mldr = new MLeader();
                    mldr.LeaderLineType = LeaderType.StraightLeader;
                    /* --- add other properties here --- */
                    mldr.AddLeaderLine(arrowPoint);
                    mldr.AddFirstVertex(0, arrowPoint);
                    mldr.AddFirstVertex(1, symbolPoint);
                    mldr.ArrowSymbolId = db.Dimldrblk;
                    DBDictionary dict = (DBDictionary)tr.GetObject(db.MLeaderStyleDictionaryId, OpenMode.ForRead);
                    ObjectId mlstyleid = dict.GetAt("Standard");
                    mldr.MLeaderStyle = mlstyleid;
                    mldr.ContentType = ContentType.MTextContent;
                    mldr.MText = mtxt;
                    mldr.TextLocation = symbolPoint;
                    mldr.SetDogleg(0, vec);
                    mldr.LandingGap = th/4;
                    mldr.DoglegLength = th;
                    btr.AppendEntity(mldr);
                    tr.AddNewlyCreatedDBObject(mldr, true);
                    tr.Commit();
                catch (Autodesk.AutoCAD.Runtime.Exception ex)
                    ed.WriteMessage(ex.Message + "\n" + ex.StackTrace);
                finally
                    Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("dimldrblk", dimld);
{code}
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
