• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Member
    SendStringToExecute
    869 Views, 11 Replies
    03-19-2012 07:48 AM
     Hi Everybody
    When the code below are executed the line, drawing the line are executed after the rest of the code,
    that is the msgboxes are displayed before the line are drawn in Acad_Window.
    what should be done to display the  msgboxes before the line, as the order in the code indicates
    Hope someone has an explanation and solution to this
    With Regards
    HansP
    Application.DocumentManager.MdiActiveDocument.SendStringToExecute("line_
    1800,2001600,3000 ", True, False, True)
    MsgBox("DWG Saved")
    dwgPath = ThisDrawing.GetVariable("DWGPREFIX")
    dwgName = ThisDrawing.GetVariable("DWGNAME")
    Dim thisDwg AsString = dwgPath + dwgName
    MsgBox(thisDwg)
    Please use plain text.
    *Expert Elite*
    Re: SendStringToExecute
    03-19-2012 08:14 AM in reply to: Hans530
    What you should do is to use the .NET API to
    • Start a Transaction
    • Construct a Line object, such as:
      Dim l as Line=New Line
      Line.StartPoint=New Point3d(....)
      Line.EndPoint=New Point3d(...)
    • Set the line's properties as needed
    • Append the line to targeting space (Model or layout)
    • Commit the transaction
    You can create a command method to cover all the steps aforemention, and then use SendStringToExecution() method as one call.
    If the intention is to use all Acad existing/built-in commands, use AutoCAD script would do in most cases.
    Active Member
    03-19-2012 08:23 AM in reply to: Hans530
    Thank you for your quick responce
    The line worked fine, but how to do with a zoom command.
    Hans P
    ranjith0326
    03-19-2012 10:05 PM in reply to: Hans530
    Try with below one
    Application.DocumentManager.MdiActiveDocument.SendStringToExecute("zoom e ", True, False, True)
    R.Ranjith
    Moderator
    Alexander.Rivilis
    03-19-2012 11:30 PM in reply to: Hans530
    http://forums.autodesk.com/t5/NET/ZoomWindow-and-ZoomScale/m-p/3249340#M26321
    Пожалуйста не забывайте про Утвердить в качестве решения!Утвердить в качестве решения и Give Kudos!Баллы
    Please remember to Accept Solution!Accept as Solution and Give Kudos!Kudos
    Active Member
    03-20-2012 03:57 AM in reply to: Alexander.Rivilis
    I do not know anything about C# so, I translated the ZoomExtents like this. It compiled OK but there was a runtime error complaining about the BindingFlags. As I don’t know any C# and as it seems not enough VB either to translate that part of the code where several BindingFlags are listid. I must ask for further help with that part
    Thanks in advance Hans P
    public static void ZoomExtents()
            object acad = Application.AcadApplication;
            acad.GetType().InvokeMember("ZoomExtents", BindingFlags.DeclaredOnly | BindingFlags.Public |
                 BindingFlags.Instance | BindingFlags.InvokeMethod, null, acad, null);
    Public Sub ZoomExtents()
    Dim acad As Object = Application.AcadApplication
    acad.GetType().InvokeMember("ZoomExtents",BindingFlags.DeclaredOnly, Nothing, acad, Nothing)
    End Sub
    Moderator
    Alexander.Rivilis
    03-20-2012 03:59 AM in reply to: Hans530
    Imports System.Reflection
    Active Member
    03-20-2012 04:37 AM in reply to: Alexander.Rivilis
    I had that one without that it wouldn't compile
    But is the row
    translated ok from C#
     Hans P
    Moderator
    Alexander.Rivilis
    03-20-2012 04:44 AM in reply to: Hans530
    acad.GetType().InvokeMember("ZoomExtents",BindingFlags.InvokeMethod, Nothing, acad, Nothing)
    *Expert Elite*
    03-20-2012 03:08 PM in reply to: Alexander.Rivilis
    While using Reflection/Late binding, we can use some (extension) methods to make the code more readable than the :
    GetType().InvokeMember(...)
    With C# and Framework 3.5 or upper, we can write some extension methods so that the upper expression to ma make zoom extents become:
    acad.Invoke("ZoomExtents");
    or, to set the cursor size to 10:
    acad.Get("Preferences").Get("Display").Set("CursorSize", 10);
    public static class LateBinding
    	public static object Get(this object obj, string propName, params object[] parameter)
    		return obj.GetType().InvokeMember(propName, BindingFlags.GetProperty, null, obj, parameter);
    	public static void Set(this object obj, string propName, params object[] parameter)
    		obj.GetType().InvokeMember(propName, BindingFlags.SetProperty, null, obj, parameter);
    	public static object Invoke(this object obj, string methName, params object[] parameter)
    		return obj.GetType().InvokeMember(methName, BindingFlags.InvokeMethod, null, obj, parameter);
    With F#, it's really easy to extend any Type, but ther's no way (AFAIK) to use optional parameters (as with params or ParamArray), but creating an array is so simple.
    The zoom extents:
    acad.invoke("ZoomExtents", null) |> ignore
    The cursor to 10:
    let size = acad.get("Preferences", null).get("Display", null).set("CursorSize", [| 10 |])
    type Object with
        member x.get(propName, parameter) =
            x.GetType().InvokeMember(propName, BindingFlags.GetProperty, null, x, parameter)
        member x.set(propName, parameter) =
            x.GetType().InvokeMember(propName, BindingFlags.SetProperty, null, x, parameter)
            |> ignore
        member x.invoke (propName, parameter) =
            x.GetType().InvokeMember(propName, BindingFlags.InvokeMethod, null, x, parameter)
    VB do not allow to use extension methods with the Object Type, but we can define methods so that late binding expressions look like the vlax-get, vlax-put, and vlax,invoke LISP functions.
    The zoom extents:
    Invoke(acad, "ZoomExtents")
    The cursor to 10:
    SetProperty(GetProperty(GetProperty(acad, "Preferences"), "Display"), "CursorSize", 10)
    Module LateBindingExtensions
        Public Function GetProperty(ByVal obj As Object, ByVal propName As String, ByVal ParamArray parameter As Object()) As Object
            Return obj.GetType().InvokeMember(propName, BindingFlags.GetProperty, Nothing, obj, parameter)
        End Function
        Public Sub SetProperty(ByVal obj As Object, ByVal propName As String, ByVal ParamArray parameter As Object())
            obj.GetType().InvokeMember(propName, BindingFlags.SetProperty, Nothing, obj, parameter)
        End Sub
        Public Function Invoke(ByVal obj As Object, ByVal methName As String, ByVal ParamArray parameter As Object()) As Object
            Return obj.GetType().InvokeMember(methName, BindingFlags.InvokeMethod, Nothing, obj, parameter)
        End Function
    End Module
    Gilles Chanteau
