SendStringToExecute
SendStringToExecute
Hans530
Message 1 of 14
SendStringToExecute
Hans530
Hi Everybody
When the code below are executed the line, drawing the line are executed after the rest of the code,
that is the msgboxes are displayed before the line are drawn in Acad_Window.
what should be done to display the  msgboxes before the line, as the order in the code indicates
Hope someone has an explanation and solution to this
With Regards
HansP
Application.DocumentManager.MdiActiveDocument.SendStringToExecute("line_
1800,2001600,3000 ", True, False, True)
MsgBox("DWG Saved")
dwgPath = ThisDrawing.GetVariable("DWGPREFIX")
dwgName = ThisDrawing.GetVariable("DWGNAME")
Dim thisDwg AsString = dwgPath + dwgName
MsgBox(thisDwg)
Replies (13)
Message 2 of 14
norman.yuan
What you should do is to use the .NET API to
  • Start a Transaction
  • Construct a Line object, such as:
  Dim l as Line=New Line
  Line.StartPoint=New Point3d(....)
  Line.EndPoint=New Point3d(...)
  • Set the line's properties as needed
  • Append the line to targeting space (Model or layout)
  • Commit the transaction
You can create a command method to cover all the steps aforemention, and then use SendStringToExecution() method as one call.
If the intention is to use all Acad existing/built-in commands, use AutoCAD script would do in most cases.
Norman Yuan
Drive CAD With Code
Message 3 of 14
Hans530
Thank you for your quick responce
The line worked fine, but how to do with a zoom command.
Hans P
Message 4 of 14
Try with below one
Application.DocumentManager.MdiActiveDocument.SendStringToExecute("zoom e ", True, False, True)
Message 5 of 14
Alexander.Rivilis
http://forums.autodesk.com/t5/NET/ZoomWindow-and-ZoomScale/m-p/3249340#M26321
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 6 of 14
Hans530
I do not know anything about C# so, I translated the ZoomExtents like this. It compiled OK but there was a runtime error complaining about the BindingFlags. As I don’t know any C# and as it seems not enough VB either to translate that part of the code where several BindingFlags are listid. I must ask for further help with that part
Thanks in advance Hans P
public static void ZoomExtents()
        object acad = Application.AcadApplication;
        acad.GetType().InvokeMember("ZoomExtents", BindingFlags.DeclaredOnly | BindingFlags.Public |
             BindingFlags.Instance | BindingFlags.InvokeMethod, null, acad, null);
Public Sub ZoomExtents()
Dim acad As Object = Application.AcadApplication
acad.GetType().InvokeMember("ZoomExtents",BindingFlags.DeclaredOnly, Nothing, acad, Nothing)
End Sub
Message 7 of 14
Alexander.Rivilis
Imports System.Reflection
Expert Elite Member
Message 8 of 14
Hans530
I had that one without that it wouldn't compile
But is the row
translated ok from C#
 Hans P
Message 9 of 14
Alexander.Rivilis
acad.GetType().InvokeMember("ZoomExtents",BindingFlags.InvokeMethod, Nothing, acad, Nothing)
Expert Elite Member
Message 10 of 14
_gile
While using Reflection/Late binding, we can use some (extension) methods to make the code more readable than the :
GetType().InvokeMember(...)
With C# and Framework 3.5 or upper, we can write some extension methods so that the upper expression to ma make zoom extents become:
acad.Invoke("ZoomExtents");
or, to set the cursor size to 10:
acad.Get("Preferences").Get("Display").Set("CursorSize", 10);
public static class LateBinding
	public static object Get(this object obj, string propName, params object[] parameter)
		return obj.GetType().InvokeMember(propName, BindingFlags.GetProperty, null, obj, parameter);
	public static void Set(this object obj, string propName, params object[] parameter)
		obj.GetType().InvokeMember(propName, BindingFlags.SetProperty, null, obj, parameter);
	public static object Invoke(this object obj, string methName, params object[] parameter)
		return obj.GetType().InvokeMember(methName, BindingFlags.InvokeMethod, null, obj, parameter);
With F#, it's really easy to extend any Type, but ther's no way (AFAIK) to use optional parameters (as with params or ParamArray), but creating an array is so simple.
The zoom extents:
acad.invoke("ZoomExtents", null) |> ignore
The cursor to 10:
let size = acad.get("Preferences", null).get("Display", null).set("CursorSize", [| 10 |])
type Object with
    member x.get(propName, parameter) =
        x.GetType().InvokeMember(propName, BindingFlags.GetProperty, null, x, parameter)
    member x.set(propName, parameter) =
        x.GetType().InvokeMember(propName, BindingFlags.SetProperty, null, x, parameter)
        |> ignore
    member x.invoke (propName, parameter) =
        x.GetType().InvokeMember(propName, BindingFlags.InvokeMethod, null, x, parameter)
VB do not allow to use extension methods with the Object Type, but we can define methods so that late binding expressions look like the vlax-get, vlax-put, and vlax,invoke LISP functions.
The zoom extents:
Invoke(acad, "ZoomExtents")
The cursor to 10:
SetProperty(GetProperty(GetProperty(acad, "Preferences"), "Display"), "CursorSize", 10)
Module LateBindingExtensions
    Public Function GetProperty(ByVal obj As Object, ByVal propName As String, ByVal ParamArray parameter As Object()) As Object
        Return obj.GetType().InvokeMember(propName, BindingFlags.GetProperty, Nothing, obj, parameter)
    End Function
    Public Sub SetProperty(ByVal obj As Object, ByVal propName As String, ByVal ParamArray parameter As Object())
        obj.GetType().InvokeMember(propName, BindingFlags.SetProperty, Nothing, obj, parameter)
    End Sub
    Public Function Invoke(ByVal obj As Object, ByVal methName As String, ByVal ParamArray parameter As Object()) As Object
        Return obj.GetType().InvokeMember(methName, BindingFlags.InvokeMethod, Nothing, obj, parameter)
    End Function
End Module
Gilles Chanteau
GileCAD
GitHub
Message 11 of 14
_gile
Another way using F# is to define three functions so that the arguments order allows to use the "pipe forward" operator (|>).
let get prop param obj =
    obj.GetType().InvokeMember(prop, BindingFlags.GetProperty, null, obj, param)
let set prop param obj =
    obj.GetType().InvokeMember(prop, BindingFlags.SetProperty, null, obj, param) |> ignore
let invoke meth param obj =
    obj.GetType().InvokeMember(meth, BindingFlags.InvokeMethod, null, obj, param)
[<CommandMethod("foo")>]
let foo() =
    let acad = Application.AcadApplication
    acad |> invoke "ZoomExtents" null |> ignore
    acad |> get "Preferences" [||] |> get "Display" [||] |> set "CursorSize" [| 5 |]
Gilles Chanteau
GileCAD
GitHub
Message 12 of 14
Hans530
Thank you all for your responce
Hans P
Message 13 of 14
cadApp.GetType().InvokeMember("ZoomExtents", BindingFlags.InvokeMethod, null, cadApp, null);
Message 14 of 14
BKSpurgeon
why use string to execute when you can do this:
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2015/ENU/AutoCAD-NET/files/GUI...
code which draws a line.
