.NET
*Tony Tanzillo
Message 1 of 8 (341 Views)
SendStringToExecute
341 Views, 7 Replies
07-05-2005 07:26 PM
SendStringToExecute
I'm having a problem with this, if the user has typed
something on the command line, but has not pressed
enter.
Is there any API (C++, undocumented or not) that can
tell me if keystrokes have been typed at the "Command: "
prompt, but enter/space hasn't been pressed?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006
http://www.acadxtabs.com
*Owen Wengerd
Message 2 of 8 (341 Views)
Re: SendStringToExecute
07-05-2005 08:41 PM in reply to: *Tony Tanzillo
Tony:
Maybe 'acedIsInputPending' exported by acad.exe? I've never tried it, but
it's a good bet. :smileyhappy:
Owen Wengerd
President, ManuSoft ==> http://www.manusoft.com
VP Americas, CADLock, Inc. ==> http://www.cadlock.com
*Tony Tanzillo
Message 3 of 8 (341 Views)
07-06-2005 07:30 PM in reply to: *Tony Tanzillo
Hi Owen. Thanks, tried that, no luck.
I know AutoCAD checks this, because it doesn't
respond to mouse clicks in the drawing window if
there's something typed.
"Owen Wengerd" wrote in message news:4893409@discussion.autodesk.com...
Tony:
Owen Wengerd
*Albert Szilvasy
Message 4 of 8 (341 Views)
07-07-2005 10:02 AM in reply to: *Tony Tanzillo
Have you tried Application.IsQuiescent ?
Albert
"Tony Tanzillo" wrote in message
news:4894610@discussion.autodesk.com...
Tony:
Owen Wengerd
*Tony Tanzillo
Message 5 of 8 (341 Views)
07-07-2005 03:51 PM in reply to: *Tony Tanzillo
Hi Albert - That did it, thanks.
"Albert Szilvasy" wrote in message news:4895269@discussion.autodesk.com...
Albert
Tony:
Owen Wengerd
*Tony Tanzillo
Message 6 of 8 (341 Views)
07-07-2005 06:13 PM in reply to: *Tony Tanzillo
If IsQuiescent returns false when keystrokes are on the
command line, why does Editor.LeavingQuiescentState
not fire when the first keystroke is typed?
And, if I erase all of the keystrokes with Backspace,
then shouldn't EnteringQuiescentState fire?
Albert
Tony:
Owen Wengerd
*Albert Szilvasy
Message 7 of 8 (341 Views)
07-07-2005 07:33 PM in reply to: *Tony Tanzillo
Sound like a bug to me but I suspect it has been this way for long enough
that fixing it would cause harm than good.
Albert
news:4895896@discussion.autodesk.com...
Albert
Tony:
Owen Wengerd
*Tony Tanzillo
Message 8 of 8 (341 Views)
07-08-2005 07:06 AM in reply to: *Tony Tanzillo
Thanks. You might want to make note that when dynamic
input is enabled and keystroke input goes to the edit box
at the cursor, IsQuiescent returns true even when keystrokes
have been entered.
"Albert Szilvasy" wrote in message news:4895873@discussion.autodesk.com...
Albert
Albert
Tony:
Owen Wengerd
You are not logged in.
Ask the Community
