.NET
SendStringToExecute space bomb
5 REPLIES 5
457 Views, 5 Replies
I dont know if this behavior is consistent, but using "sendstring" in order to load a cui file
bombs if the name/path of the file has spaces in it. The following command hoses miserably
if "tbCuiName" is something like "c:\\program files\\blah blah"
Application.DocumentManager.MdiActiveDocument.SendStringToExecute("cuiload " + tbCuiName + " filedia 1 ", false, false, false);
I REALLY need to load this file, is there a workaround?
Thanks, Perry
5 REPLIES 5
Perry:
File names with spaces need to be enclosed in double quotes. 🙂
Owen Wengerd
President, ManuSoft ==> http://www.manusoft.com
VP Americas, CADLock, Inc. ==> http://www.cadlock.com
Owen Wengerd wrote:
> Perry:
Thanks Owen
the variable I was sending to sendstring evaluates so:
"C:\\Documents and Settings\\perry\\My Documents\\My code\\C#\\Acad\\Tblocker2007\\bin\\Debug\\tblocker.cui"
However, if I move the cui file and call the command with:
"c:\\tblocker.cui"
it works
SendStringToExecute("\"C:\My filename with spaces.txt\"");
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
"perry" wrote in message news:5192653@discussion.autodesk.com...
Owen Wengerd wrote:
> Perry:
Thanks Owen
"c:\\tblocker.cui"
it works
"Double Double" quotes?
You know, I actually thought about doing that Tony,
then I thought, Naw, that would be silly!
Well, I tacked extra quotes to the variable which now evaluates to:
"\"C:\\Documents and Settings\\perry\\My Documents\\My code\\C#\\Acad\\Tblocker2007\\bin\\Debug\\tblocker.cui\""
and it work, seems odd but as long as it works thats all that matters.
”Boost
