Dan,
in order to interact with AutoCAD through COM you need to use the Registry name like this:
oAcadApp = CreateObject("AutoCAD.Application.17") ' this creates a new instance of AutoCAD
OR
oAcadApp = GetObject("AutoCAD.Application.17") ' this finds a running instance of AutoCAD and attaches to it
FYI, the .17 is the version of autoCAD, if you leave that off, it will open the last opened version which may or may not be what you need.
