.NET
Valued Contributor
scarta
Message 1 of 9 (195 Views)
Send command from a showmodaldialog
195 Views, 8 Replies
03-27-2014 05:05 AM
Hi, I need to write a new command that convert a lot of DGN file to DWG
I use a FORM with a ListBox where I drag&drop dgn file. I use the form with Shwmodaldialog.
When i click ok button the SendStringToExecute don'work
There is a way for send a command from showmodaldialog form?
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Colors
Imports System
Imports System.Windows.Forms
Imports System.Math
'Imports System.Web.Mail
Imports Microsoft.Office.Core
Imports Microsoft.Office.Interop
'Imports Microsoft.Office.Interop.Outlook
Imports System.Runtime.InteropServices
Imports Autodesk.AutoCAD.Interop
Imports X = Microsoft.Office.Interop.Excel
Imports Autodesk.AutoCAD.DatabaseServices.Region
Imports System.Type
Imports System.IO
Imports AcWin = Autodesk.AutoCAD.Windows
'formati saveas
'MC0.0 - DWG from Rel. 1.1
'AC1.2 - DWG from Rel. 1.2
'AC1.4 - DWG from Rel. 1.4
'AC1.50 - DWG from Rel. 2.0
'AC2.10 - DWG from Rel. 2.10
'AC1002 - DWG from Rel. 2.5
'AC1003 - DWG from Rel. 2.6
'AC1004 - DWG from Rel.9
'AC1006 - DWG from Rel.10
'AC1009 - DWG from Rel.11/12 (or LT R1/R2)
'AC1012 - DWG from Rel.13 (or LT95)
'AC1014 - DWG from Rel.14, 14.01 (or LT97/LT98)
'AC1015 - DWG from AutoCAD 2000/2000i/2002 (or LT, Map or relative Desktop version)
'AC1018 - DWG from AutoCAD 2004/2005/2006 (or other product in the "2004", "2005" or "2006" family)
'AC1021 - DWG from AutoCAD 2007/2008/2009 (or other product of the "2007", "2008" and "2009" families)
'AC1024 - DWG from AutoCAD 2010 (or other product of the "2010" family)
Public Class DgnToDWG
    Public num_digit As Integer = 0
    <CommandMethod("dgn2dwg", CommandFlags.Session)> _
    Public Sub BatchDGN_Import()
        Dim DVLAY As New DivLAY
        Dim strNomeFile As String
        Dim myDWG As ApplicationServices.Document
        Dim myEd As EditorInput.Editor
        Dim LockMode As Boolean = False
        Dim Frm1 As New DgnToDWG_FRM
        Dim FrmProg As New Form1
        FrmProg.TopMost = True
        Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(Frm1)
        myDWG = ApplicationServices.Application.DocumentManager.MdiActiveDocument
        myDWG.LockDocument()
        Frm1.ProgressBar1.Minimum = 0
        Frm1.ProgressBar1.Maximum = Frm1.ListDWG.Items.Count
        Frm1.Label_NT.Text = Frm1.ListDWG.Items.Count
        Frm1.TopMost = True
        Frm1.Show()
        Frm1.ButtonOk.Enabled = False
        Frm1.Label_NC.Text = 0
        Frm1.Close()
        For Each Item As Object In Frm1.ListDWG.Items
            Try
                Dim sendSTR As String
                sendSTR = "-dgnimport " & Item.ToString & " " & " " & " "
                Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.SendStringToExecute("-dgnimport " & Item.ToString & vbCr & vbCr & vbCr & vbCr, False, False, True) ' Importo il file DGN
                myDWG = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
                LockMode = True
                Dim pos_Last_BackSlash As Integer
                Dim strPath As String = ""
                Dim origin_file As String = ""
                Dim file_Sorg As String = ""
                'Dim strPath As String = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("dwgprefix")
                'Dim origin_file As String = strPath & Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("dwgname")
                'Dim file_Sorg As String = Autodesk.AutoCAD.ApplicationServices.Application.GetSystemVariable("dwgname")
                Dim n As Integer = 1
                pos_Last_BackSlash = Item.ToString.LastIndexOf("\")
                If pos_Last_BackSlash = -1 Then pos_Last_BackSlash = Item.ToString.IndexOf("\")
                origin_file = Item.ToString.Substring(pos_Last_BackSlash + 1)
                strPath = Item.ToString.Substring(0, pos_Last_BackSlash + 1)
                file_Sorg = origin_file.Remove(origin_file.Length - 4, 4)
                DVLAY.Show()
                DVLAY.TopMost = True
                DVLAY.ProgressBar1.Value = 0
                DVLAY.ProgressBar1.Minimum = 0
                DVLAY.ProgressBar1.Maximum = Frm1.ListDWG.Items.Count
                strNomeFile = strPath & file_Sorg
                myDWG.Database.SaveAs(strNomeFile, True, DwgVersion.AC1024, myDWG.Database.SecurityParameters)
                'myDwg.LockDocument()
                myDWG.Editor.Regen()
                DVLAY.ProgressBar1.Value += 1
                System.Windows.Forms.Application.DoEvents()
                DocumentExtension.CloseAndDiscard(myDWG)
                DVLAY.Hide()
            Catch ex As Global.System.Runtime.InteropServices.COMException
                '  myFSTarg.WriteLine("errore" & txtLine)
                If LockMode = True Then
                    myDWG.LockDocument.Dispose()
                    myDWG.Editor.UpdateScreen()
                    Frm1.Close()
                GoTo a101
            End Try
            LockMode = False
            'aggiorno progressbar
            Frm1.ProgressBar1.Value = Frm1.ProgressBar1.Value + 1
            Frm1.Label_NC.Text = Frm1.Label_NC.Text + 1
            Frm1.ProgressBar1.Update()
            Frm1.ProgressBar1.Refresh()
            Frm1.Update()
            ' Frm1.Label_NC.Text = Frm1.Label_NC.Text + 1
        Next
        'FrmProg.Button1.Visible = True
a101:
        Frm1.Button_Fatto.Enabled = True
        ' If int_Status = 0 Then GoTo a200
        'myTrans.Dispose()
        'a103:   MsgBox("Elaborazione terminata!!!")
    End Sub
End Class
Active Contributor
DesignProQuig
Message 2 of 9 (190 Views)
Re: Send command from a showmodaldialog
03-27-2014 05:16 AM in reply to: scarta
You could just add the sub to the button event when it's pressed: "Public Sub BatchDGN_Import()"  Or look at send string to execute.
http://www.designprosoftware.co.uk/
Valued Contributor
scarta
Message 3 of 9 (180 Views)
03-27-2014 06:10 AM in reply to: DesignProQuig
Thank
Valued Contributor
scarta
Message 4 of 9 (178 Views)
03-27-2014 06:18 AM in reply to: DesignProQuig
Sorry but I don't understand..
Why the line SendStringToExecute("-dgnimport " & Item.ToString & vbCr & vbCr & vbCr & vbCr, False, False, True) don't work?
There is a way for send a command when a form is in modal mode?
Active Contributor
DesignProQuig
Message 5 of 9 (170 Views)
03-27-2014 06:47 AM in reply to: scarta
I'm not at my PC today but did you also try putting the sub in the button click event?
Public Sub BatchDGN_Import().
Have a search on here there must be lots of examples of send string to execute. :smileyvery-happy:
Valued Contributor
scarta
Message 6 of 9 (163 Views)
03-27-2014 07:15 AM in reply to: DesignProQuig
I  have put the sub in the button, but not working....
Valued Contributor
scarta
Message 7 of 9 (161 Views)
03-27-2014 07:30 AM in reply to: DesignProQuig
There is an api procedure or class for import DGn file without use the send command?
Valued Contributor
scarta
Message 8 of 9 (152 Views)
03-27-2014 08:39 AM in reply to: DesignProQuig
I try another way: insert the dgn file as xref but I receive an error "efileaccesserr" on the line
Dim xrefObj As ObjectId = db.AttachXref("c:\prova1.dgn", "prova")
Why?
        Dim acDocMgr As DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
            Try
                'Dim sendSTR As String
                'sendSTR = "-dgnimport " & Item.ToString & " " & " " & " "
                'Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.SendStringToExecute("-dgnimport " & Item.ToString & vbCr & vbCr & vbCr & vbCr, False, False, True) ' Importo il file DGN
                LockMode = True
                ' Attach the Xref
                'myDWG = DocumentCollectionExtension.Open(acDocMgr, "C:\menu2000\ACA2014\acad2014.dwt", False)
                Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
                Dim db As Database = doc.Database
                Using trans As Transaction = db.TransactionManager.StartTransaction()
                    ' Attach the Xref
                    Dim br As New BlockReference(New Point3d(0, 0, 0), xrefObj)
                    ' Add the xref to model space
                    Dim bt As BlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForRead)
                    Dim modelSpace As BlockTableRecord = trans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
                    modelSpace.AppendEntity(br)
                    trans.AddNewlyCreatedDBObject(br, True)
                    trans.Commit()
                End Using
                DVLAY.Show()
                DVLAY.Hide()
                    Frm1.Close()
                GoTo a101
            End Try
            LockMode = False
            Frm1.Update()
        Next
a101:
        'myTrans.Dispose()
    End Sub
ADN Support Specialist
Virupaksha.aithal
Message 9 of 9 (115 Views)
04-01-2014 04:33 AM in reply to: scarta
Refer blog item http://adndevblog.typepad.com/autocad/2012/06/invoking-the-measure-command-using-sendcommand-in-vbne... which explains why the SendStringToExecute is not working as expected. As explained in blog, use ActiveX SendCommand API.
rmal>Note:
1.         Do not send us any information that you consider to be a trade secret to your company
2.         Code snippets will not help us, because they don't allow us to reproduce the context in which the code runs
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
You are not logged in.
Announcements
Need installation help?
Ask the Community
