.NET
Amremad
Message 1 of 7 (334 Views)
SelectionSet Question(New Pointer, With Keyword)
334 Views, 6 Replies
04-02-2013 02:05 AM
Hello Every one,
iam so happy to start finally start acutal program using .net
this is a good time for me
so i will ask the first actual question in the field
i asked before this question in VBA Forum but no answer there so the people advice me to use .net to solve this problem.
my question about selectionset :
1- how can i do SelectionSet With KeyWord like following picture
2- how can i change mouse pointer on selectionset like picture
 3- how can i make selectionset with one determine object like block (allow to select one only)
thx for you
Amremad
Message 2 of 7 (315 Views)
Re: SelectionSet Question(New Pointer, With Keyword)
04-02-2013 06:05 AM in reply to: Amremad
any solution
norman.yuan
Message 3 of 7 (309 Views)
04-02-2013 07:06 AM in reply to: Amremad
You look into various GetXXXX() method of Editor class, with appropriate PromptXXXXOptions class and/or SelectionFilter class being used as argument in those GetXXXX() method.
For your question 1, depending on your actual need, you can either use Editor.GetSelection() to select one entity or more entities, or you can use GetEntity() to select one entity at a time. All those GetXXX() method takes PromptXXXXOptions as argument, in which you can define keyword.
the code would look like (not tested, in C#)
PromptSelectionOptions opt=new Promp[tSelectionOptions();
opt.MessageForAdding="\nSelect object on layer xxx:";
opt......
opt.Keywords.Add("Settings");
opt.Keywords.Defalut="Settings";
PromptSelectionResult res=ed.GetSelection(opt);
if (res.Status==PromptStatus.OK || res.Status==PromptStatus.Keyword)
  ''If status is OK, do something with the selectionset in the PromptSelectionResult object
  ''If the status is Keyword, do something according to the keyword value
As for changing cursor during selecting, the various PromptXXXXOptions class' do not provide a way to do that. I am not aware of anything we can do (at least up to Acad2012 I am currently using);
for your last question, you can create a SelectionFilter (which I saw you have used it in your other post) and use it in GetSelection() method as the second argument. if you only want to select one entity(block), then you can use GetEntity() method in conjunction with PromptEntityOption class, in which you can set allowed entity (blockreference only, for example).
HTH.
Amremad
Message 4 of 7 (286 Views)
04-03-2013 12:46 AM in reply to: norman.yuan
thank you mr norman
in first question i made this function but doesn't work
    <CommandMethod("tst")> _
    Public Sub testing()
        Dim TypedValues(0) As TypedValue
        TypedValues.SetValue(New TypedValue(DxfCode.BlockName, "AMR.LEVEL"), 0)
        Dim AcSelFtr As SelectionFilter = New SelectionFilter(TypedValues)
        Dim AcSelOption As PromptSelectionOptions = New PromptSelectionOptions
        AcSelOption.MessageForAdding = ("\nSelect Object on Layer XXX")
        AcSelOption.Keywords.Add("Settings")
        AcSelOption.Keywords.Default = "Settings"
        Dim AcSelPrompt As PromptSelectionResult
        AcSelPrompt=Application.DocumentManager.MdiActiveDocument.Editor.GetSelection(AcSelOption, AcSelFtr)
    End Sub
 Settings doesn't work in this code why?
Amremad
Message 5 of 7 (283 Views)
04-03-2013 01:16 AM in reply to: Amremad
i fixed my code and now is work
        ' create selection filter with typedvalues
        'create keywords options for selection
        AcSelOption.MessageForAdding = ("\nSelect Object on Layer or " & AcSelOption.Keywords.GetDisplayString(True))
        'start selectionset with keywords and filter
        AcSelPrompt = Application.DocumentManager.MdiActiveDocument.Editor.GetSelection(AcSelOption, AcSelFtr)
        If AcSelPrompt.Status = PromptStatus.OK Then
        End If
    End Sub
how can i handle the keyword or selection that user input it ,
norman.yuan
Message 6 of 7 (272 Views)
04-03-2013 06:41 AM in reply to: Amremad
        End If
    End Sub
As shown in my previous reply, you test PromptSelectionResult.Status for both OK, or Keyword:
    Dim ObjIds() As ObjectId=AcSelPrompt.Value.GetObjectIds()
    ''Do something with the obtained objectId array
ElseIf AcSelPrompt.Status==PromptStatus.Keyword Then
  'Since you only have one keyword, you do not have to test
  ''which keyword is selected
  ''Just do something to configure settings
Else
   Return
End If
I almost alway set a default keyword (PromptxxxxOption.Keyword.Default="xxxxx"), even there is only one keyword used. This way, user can simply hit Enter/Space to get the keyword selected, as opposed to having to enter a key as keyword and then hit Enter/Space. This make your user a bit happier.
Amremad
Message 7 of 7 (246 Views)
04-17-2013 06:11 AM in reply to: Amremad
this is correct solution
    Public Shared Sub EditInformation()
        TypedValues.SetValue(New TypedValue(DxfCode.BlockName, "BIO.Doc.Info"), 0)
        AddHandler AcSelOption.KeywordInput, AddressOf handle_KeywordInput
        End If
    End Sub
    Private Shared Sub handle_KeywordInput(ByVal sender As Object, ByVal e As SelectionTextInputEventArgs)
        MsgBox(e.Input.ToString)
    End Sub
You are not logged in.
Ask the Community
