• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    .NET
    Active Contributor as
    Active Contributor
    Selection Set in VB.Net
    721 Views, 9 Replies
    06-13-2005 04:01 AM
    I trie to create as Selection set in VB.Net, if I do not use any filters it functions well, but when I trie to use the filter option I get an Error.
    This is the code:
    Friend Function SelectionSet_Create(ByVal Name As String, ByVal Point3dList() As Point3d, ByVal ObjectName As String) As AcadSelectionSet
    Dim acadApp As AcadApplication
    Dim acadDoc As AcadDocument
    Dim SSObj As AcadSelectionSet
    Dim SSmode As Autodesk.AutoCAD.Interop.Common.AcSelect
    Dim PointsArray As Array = PointlistToArray(Point3dList)
    Try
    acadApp = CType(GetObject(, AutoCadApplicatie), AcadApplication)
    acadApp.Visible = True
    acadDoc = acadApp.ActiveDocument
    acadDoc.Application.Visible = True
    SSObj = acadDoc.SelectionSets.Add(Name)
    SSmode = Autodesk.AutoCAD.Interop.Common.AcSelect.acSelectionSetCrossingPolygon
    If ObjectName "*" Then
    Dim FilterType(0) As Integer : FilterType(0) = 2
    Dim FilterData(0) As String : FilterData(0) = ObjectName
    SSObj.SelectByPolygon(SSmode, PointsArray, FilterType, FilterData)
    Else
    SSObj.SelectByPolygon(SSmode, PointsArray)
    SSObj.Highlight(True)
    Autodesk.AutoCAD.ApplicationServices.CommandLinePrompts.Message(vbCrLf & SSObj.Count & " Objects selected" + vbCrLf)
    Catch ex As Exception
    MessageBox.Show(ex.ToString)
    Return Nothing
    End Try
    End Function
    And this is the error I get is attached.
    What is going wrong ?
    Harold van Aarsen
    The Netherlands
    Please use plain text.
    Active Contributor
    Re: Selection Set in VB.Net
    06-13-2005 04:34 AM in reply to: as
    I have replaced the text :
    with :
    Dim FilterType() As Int16 = {2}
    Dim FilterData() As Object = {"Hsb_DbElement"}
    and now it functions well.
    Active Contributor
    06-13-2005 08:56 PM in reply to: as
    There is a bug in the managed wrapper class.You can use my DOTNETARX library to use the filter option in Selection sets.
    Active Contributor
    06-13-2005 08:59 PM in reply to: as
    I'm sorry,you use the com!You should replace
    with
    Dim FilterType(0) As short
    Active Contributor
    06-13-2005 10:14 PM in reply to: as
    You are right
    *technosterone
    06-29-2005 04:12 AM in reply to: as
    Hello, Harold!
    What do you filter in your sample?
    Active Contributor
    06-29-2005 10:16 PM in reply to: as
    In this case I wanted to select some HSBcad object, but the general goal was to create some functions wich I can use in more cases.
    Beneath are the functions I created in VB.Net 2003
    #Region " Selections Sets "
    Friend Function SelectionSet_CreateWindow(ByVal Name As String, ByVal ObjectName As String) As AcadSelectionSet
    Try
    Dim FilterType() As Int16 = {0}
    Dim FilterData() As Object = {ObjectName}
    SSObj.SelectOnScreen(FilterType, FilterData)
    Return SSObj
    Return Nothing
    End Try
    End Function
    Friend Function SelectionSet_CreateAll(ByVal Name As String, ByVal ObjectName As String) As AcadSelectionSet
    Try
    SSObj.Select(AcSelect.acSelectionSetAll, , , FilterType, FilterData)
    Return SSObj
    Return Nothing
    End Try
    End Function
    Friend Function SelectionSet_Delete(ByVal Name As String) As Boolean
    Dim Obj As AcadSelectionSet
    Dim Found As Boolean = False
    Try
    For Each Obj In acadDoc.SelectionSets
    If Obj.Name = Name Then Found = True
    Next
    If Found = True Then acadDoc.SelectionSets.Item(Name).Delete()
    Return True
    Return False
    End Try
    End Function
    #End Region
    *technosterone
    07-03-2005 10:40 PM in reply to: as
    Thank you, Harold.
    Active Member
    07-21-2005 08:56 PM in reply to: as
    Since you are discussing about selectionset, I have a question regarding it. How can I make a selection set as pickfirst selection set using .NET API.
    Naveen.
    04-13-2006 08:15 PM in reply to: as
    when I try to get the selection set with this example I always get an error saying the AutoCAD window is invisible. Even if I set the visible state to true. Any idea what causes this error?
