.NET
Selection Set in VB.Net
9 REPLIES 9
Message 1 of 10
3087 Views, 9 Replies
I trie to create as Selection set in VB.Net, if I do not use any filters it functions well, but when I trie to use the filter option I get an Error.
This is the code:
Friend Function SelectionSet_Create(ByVal Name As String, ByVal Point3dList() As Point3d, ByVal ObjectName As String) As AcadSelectionSet
Dim acadApp As AcadApplication
Dim acadDoc As AcadDocument
Dim SSObj As AcadSelectionSet
Dim SSmode As Autodesk.AutoCAD.Interop.Common.AcSelect
Dim PointsArray As Array = PointlistToArray(Point3dList)
Try
acadApp = CType(GetObject(, AutoCadApplicatie), AcadApplication)
acadApp.Visible = True
acadDoc = acadApp.ActiveDocument
acadDoc.Application.Visible = True
SSObj = acadDoc.SelectionSets.Add(Name)
SSmode = Autodesk.AutoCAD.Interop.Common.AcSelect.acSelectionSetCrossingPolygon
If ObjectName "*" Then
Dim FilterType(0) As Integer : FilterType(0) = 2
Dim FilterData(0) As String : FilterData(0) = ObjectName
SSObj.SelectByPolygon(SSmode, PointsArray, FilterType, FilterData)
Else
SSObj.SelectByPolygon(SSmode, PointsArray)
End If
SSObj.Highlight(True)
Autodesk.AutoCAD.ApplicationServices.CommandLinePrompts.Message(vbCrLf & SSObj.Count & " Objects selected" + vbCrLf)
Catch ex As Exception
MessageBox.Show(ex.ToString)
Return Nothing
End Try
End Function
And this is the error I get is attached.
What is going wrong ?
Harold van Aarsen
The Netherlands
9 REPLIES 9
Message 2 of 10
I have replaced the text :
with :
Dim FilterType() As Int16 = {2}
Dim FilterData() As Object = {"Hsb_DbElement"}
and now it functions well.
Message 3 of 10
There is a bug in the managed wrapper class.You can use my DOTNETARX library to use the filter option in Selection sets.
Message 4 of 10
I'm sorry,you use the com!You should replace
with
Dim FilterType(0) As short
Message 5 of 10
You are right
Message 6 of 10
Hello, Harold!
What do you filter in your sample?
Message 7 of 10
In this case I wanted to select some HSBcad object, but the general goal was to create some functions wich I can use in more cases.
Beneath are the functions I created in VB.Net 2003
#Region " Selections Sets "
Friend Function SelectionSet_CreateWindow(ByVal Name As String, ByVal ObjectName As String) As AcadSelectionSet
Try
Dim FilterType() As Int16 = {0}
Dim FilterData() As Object = {ObjectName}
SSObj.SelectOnScreen(FilterType, FilterData)
Return SSObj
Return Nothing
End Try
End Function
Friend Function SelectionSet_CreateAll(ByVal Name As String, ByVal ObjectName As String) As AcadSelectionSet
Try
SSObj.Select(AcSelect.acSelectionSetAll, , , FilterType, FilterData)
Return SSObj
Return Nothing
End Try
End Function
Friend Function SelectionSet_Delete(ByVal Name As String) As Boolean
Dim Obj As AcadSelectionSet
Dim Found As Boolean = False
Try
For Each Obj In acadDoc.SelectionSets
If Obj.Name = Name Then Found = True
Next
If Found = True Then acadDoc.SelectionSets.Item(Name).Delete()
Return True
Return False
End Try
End Function
#End Region
Message 8 of 10
Thank you, Harold.
Message 9 of 10
Since you are discussing about selectionset, I have a question regarding it. How can I make a selection set as pickfirst selection set using .NET API.
Naveen.
Message 10 of 10
when I try to get the selection set with this example I always get an error saying the AutoCAD window is invisible. Even if I set the visible state to true. Any idea what causes this error?
”Boost
