.NET
Selection Set - Crossing polygon
4 REPLIES 4
PeterKelec3372
750 Views, 4 Replies
Hello, I am wondering, if anybody could point me to the right solution of my problem. I need to be able to select circles and polylines within a user defined polygon.
Question #1:
Is there a way to force AutoCAD to select objects only through a CP (crossing polygon) command? Can I somehow retrieve a list of points the user entered when defining the polygon boundaries?
Question #2:
Is there a way to somehow mimic the native AutoCAD crossing polygon selection routine? I have created an EntityJig object that basically retrieves points from the user and displays a closed polyline on the screen. However, I would really like to use a rubber band representation of the polyline (dashed line) and a semi-transparent fill of the area enclosed by the polyline.
Is any of this possible? Edited by: PeterKelec3372 on Nov 10, 2009 12:51 PM
4 REPLIES 4
NathTay
in reply to: PeterKelec3372
Application.DocumentManager.MdiActiveDocument.Editor.GetSelection
The Editor.GetSelection method starts a full "Select objects" command. What I want is a way to force the "Select objects" command to work only in the "CP" sub command. That is the user would only be prompted/allowed to select the crossing polygon points, nothing else. However, I would still need to somehow retrieve the entered points.
Basically, I need the ability to select and analyze circles, points, polylines, and meshes in a user specified polygonal area and I do not know how to make a polygonal entityjig with a semi-trasparent/translucent fill and dashed outline (like the "CP" command).
NathTay
"http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer's%20Guide/index.html"
NathTay
Do a search on the documentation at that link for "Select Objects in the Drawing Area".
”Boost
