.NET
Selecting entities in AutoCAD 2009 from C# Visual Studio 2008
25 REPLIES 25
Message 1 of 26
888 Views, 25 Replies
in my graduation project, I need to prompt the user from a C# Windows Application to select a line so I can access its properties .
It seems that no one in my university knows a solution for this problem .
Can I find it here ??
Plz , I really need your help .
Using AutoCAD 2009 and Visual Studio 2008 .
Best Regards ...
25 REPLIES 25
Message 21 of 26
Plz someone help me , I'm really running out of the project delivery date ....
Message 22 of 26
This thread is more and more out of topic of this
NG (.NET API NG), since your are doing VBA now. Well, see some comments inline
anyway.
hello
, here is the code I used for filling a multicolumn listbox from an excel
workbook :
Private Sub UserForm_initialize()
size=2>
Dim app As excel.Application
Dim wbook As
excel.Workbook
Dim wsheet As excel.Worksheet
Dim rg As
excel.Range
Set app = excel.Application
this line should be (notice the "New"
keyword):
Set app=New excel Application
app.Visible=True
size=2>
size=2>
If I do Excel automation, I alway make it visible
so that user know something is going on and if my code run int error, I do not
end up with a hidden Excel app left behind in Task Manager.
Of course you can try
GetObject(,"Excel.Application) to see if there is already an Excel app
instance running, so that you do not have to "New" it. Make sure you have
proper error handling
size=2>
Set wbook =
app.Workbooks.Open("C:\Materials.xlsx")
Set wsheet =
wbook.Worksheets(1)
Set rg = wsheet.Range(A1, D107)
Dim
iCol As Integer
iCol = 2
Dim iRow As Integer
For
iRow = 1 To 10 Step iRow + 1
ListBox1 = wsheet.Cells(iRow,
1).Value
Next
you need to make sure to close the workbook and
quit the Excel app
Set rg=Nothing
Set wsheet=Nothing
wbook.Close
Set wbook=Nothing
app.Quit
End Sub
but an error is appearing :
Run-time error '1004':
Method 'Range' of object
'_worksheet' failed
plz help !!!
Have you step through the code in debugging? You
should be easily identify the offending line of
code.
Message 23 of 26
Thank you for your help , but with the code you suggested an error is still occuring :
Method 'Range' of object'_Worksheet' failed
and the cause after debugging is the line :
Set org = owst.Range(A1, D107)
Message 24 of 26
norman.yuan
Shouldn't
owst.Range(A1,D107)
be
owst.Range("A1:D10")
or be
owst.Range(Cells(1,1),Cells(4,107))
Norman Yuan
Drive CAD With Code
Message 25 of 26
norman.yuan
sorry, for
I meant:
owst.Range(Cells(1,1),Cells(107,4))
Norman Yuan
Drive CAD With Code
Message 26 of 26
Now the line :
Set org = owst.Range(Cells(1, 1), Cells(107, 4))
is causing the error : Method 'Cells' of object '_Global' failed
and the line :
ListBox1 = wsheet.Cells(iRow, 1).Value
is causing the error : object needed
Best regards ...
”Boost
