.NET
SelectAll bug?
2 REPLIES 2
wesbird
329 Views, 2 Replies
SelectAll bug?
When I tried to wrote my first Selection Set function in .Net, I found this:
In my test drawing, there are
2 LWPOLYLINE, on layer 0 and ABC
2 old style Polyline, on layer 0 and ABC
2 Circle on layer 0 and ABC
when I run my test routine which will create selection set wtih different filter, here is what I got:
POLYLINE, LWPOLYLINE+ABC: 1 (wrong, correct is 2)
POLYLINE, LWPOLYLINE: 2 (wrong, correct is 4)
POLYLINE, CIRCLE+ABC: 1 (wrong, correct is 2)
POLYLINE,CIRCLE: 4 (correct)
LWPOLYLINE+ABC: 1 (correct)
LWPOLYLINE: 2 (correct)
Select All: 6
I read some article the bug in conditional filter. To my understanding, it about use -4 in the filter which I did not. If this correct, then what's wrong in my code?
here is the code:
Class.cs
using System;
using System.Collections;
using System.Globalization;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Geometry;
namespace SelectAll
/// Summary description for RSss.
// public class RSss : SelectionSet
public class RSss
public RSss()
// TODO: Add constructor logic here
// Select All, w/o filter
public static SelectionSet SelectAll()
Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
PromptSelectionResult prSelRes = ed.SelectAll();
if (prSelRes.Status != PromptStatus.OK) return null;
SelectionSet ss = prSelRes.Value;
// ddebug
// ed.WriteMessage("Number in the selection set: {0}", ss.Count);
return ss;
public static SelectionSet SelectAll(TypedValue[] values)
SelectionSet ss = null;
try
SelectionFilter filterSS = new SelectionFilter(values);
PromptSelectionResult prSelRes = ed.SelectAll(filterSS);
catch (System.Exception caught)
// ddebug
ed.WriteMessage(caught.Message.ToString());
// ddebug
// ed.WriteMessage("SelectAll2-Number in the selection set: {0}", ss.Count);
return ss;
test.cs
using System;
namespace SelectAll
/// Summary description for test.
public class test
// SelectAll2
[CommandMethod("SelectAll_TEST")]
public static void SelectAll_Test()
TypedValue[] values = new TypedValue[2] {
new TypedValue((int)DxfCode.Start, "POLYLINE, LWPOLYLINE"),
new TypedValue((int)DxfCode.LayerName, "ABC")
SelectionSet ss1 = RSss.SelectAll(values);
// ddebug
if (ss1 != null)
ed.WriteMessage("\nPOLYLINE, LWPOLYLINE+ABC: {0}", ss1.Count);
TypedValue[] values2 = new TypedValue[1] {new TypedValue((int)DxfCode.Start, "POLYLINE, LWPOLYLINE")};
SelectionSet ss2 = RSss.SelectAll(values2);
// ddebug
if (ss2 != null)
ed.WriteMessage("\nPOLYLINE, LWPOLYLINE: {0}", ss2.Count);
TypedValue[] values4 = new TypedValue[2] {
new TypedValue((int)DxfCode.Start, "POLYLINE, CIRCLE"),
SelectionSet ss4 = RSss.SelectAll(values4);
// ddebug
if (ss4 != null)
ed.WriteMessage("\nPOLYLINE, CIRCLE+ABC: {0}", ss4.Count);
TypedValue[] values3 = new TypedValue[1] {new TypedValue((int)DxfCode.Start, "POLYLINE,CIRCLE")};
SelectionSet ss3 = RSss.SelectAll(values3);
// ddebug
if (ss3 != null)
ed.WriteMessage("\nPOLYLINE,CIRCLE: {0}", ss3.Count);
TypedValue[] values6 = new TypedValue[2] {
new TypedValue((int)DxfCode.Start, "LWPOLYLINE"),
SelectionSet ss6 = RSss.SelectAll(values6);
// ddebug
if (ss6 != null)
ed.WriteMessage("\nLWPOLYLINE+ABC: {0}", ss6.Count);
TypedValue[] values5 = new TypedValue[1] {new TypedValue((int)DxfCode.Start, "LWPOLYLINE") };
SelectionSet ss5 = RSss.SelectAll(values5);
// ddebug
if (ss5 != null)
ed.WriteMessage("\nLWPOLYLINE: {0}", ss5.Count);
SelectionSet ss0 = RSss.SelectAll();
// ddebug
if (ss0 != null)
ed.WriteMessage("\n Select All: {0}", ss0.Count);
Thank you very much
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
2 REPLIES 2
fantum
in reply to: wesbird
I'm guessing here but you might try removing the spaces from "POLYLINE, LWPOLYLINE", "POLYLINE, LWPOLYLINE", and "POLYLINE, CIRCLE".
wesbird
I can't believe this is the reason. it works. Thank you very much.
Wes
”Boost
