.NET
New Member
DenisLebedev
Message 1 of 4 (961 Views)
Select all object in the drawing
961 Views, 3 Replies
06-01-2011 01:08 PM
How can I select all the objects (lines, plylines, etc) in the drawing using C# + AutoCad?
AcadSelectionSet select = _acadCurrentDocument.SelectionSets.Add("my");
select.Select(AcSelect.acSelectionSetAll);
 Trying to modify this coede, but something is missing.
BrentBurgess1980
Message 2 of 4 (944 Views)
Re: Select all object in the drawing
06-01-2011 03:05 PM in reply to: DenisLebedev
I haven't got ACAD on this computer, so I can't verify the exactness of the code, but look at the editor and the PromptSelectionOptions and PromptSelctionResult
Hallex
Message 3 of 4 (941 Views)
06-01-2011 03:08 PM in reply to: DenisLebedev
If you using AcadInterop so try this code snip:
    AcadSelectionSet oSset = doc.SelectionSets.Add("my");
                //using filter
                object miss = Type.Missing;
                short[] dxfcode= new short[]{0};
                object[] dxfvalue= new object[]{"line,polyline,circle,ellipse,text,insert"};
                oSset.Select(AcSelect.acSelectionSetAll, miss, miss, dxfcode as object, dxfvalue as object);
                //send  message to command line:
                doc.Utility.Prompt(string.Format("\nSelected: {0} objects", oSset.Count));
~'J'~
amitk_189
Message 4 of 4 (624 Views)
07-24-2012 04:25 AM in reply to: DenisLebedev
But i am using Standard EXE and how does select all work in  my case and get the texts with Origins
You are not logged in.
Ask the Community
